Tiller How do I buy a PTO for my tiller?
   / How do I buy a PTO for my tiller? #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
I have a tiller, cat 2, and it needs a PTO. Where do I buy one? What kind? Do they come in sizes?
Any help appreciated.
Bob
   / How do I buy a PTO for my tiller? #2
What brand tiller? I'm sure someone here will have the same kind and can help, but I'm thinking Tractor Supply. Some of the dealers here can probably hook you up when they know what you have.
   / How do I buy a PTO for my tiller? #5
Looking at CCM website would suggest the series five at the bottom of the page.
   / How do I buy a PTO for my tiller? #6
Tractor Supply has a pretty good selection. I think if hook up the tiller and then measure the distance from end to end TSC can help you select one.
murph
Yes, you are right
Tiller Heavy Duty with Clutch, Series V, 45" , 61", 1-3/8 Z6-QD Pin,
1-3/8 Z6-Friction Clutch 2 Discs with Bolt
Sadly, I have emailed CCM two times asking for some help on a starting point to adjust it, with no reply.
Bob
   / How do I buy a PTO for my tiller? #8
You need to know the clutch diameter. Some tillers need a smaller diameter clutch because of clearance issues.
The diameter of the two outer clutch plates is 8 inches.
Bob
   / How do I buy a PTO for my tiller? #10
Bob
Here's the pto shaft/slip clutch/shaft extension I use for my 48"-wide Yanmar RS-1200 rototill and my Kubota B7510HST.
The shaft is the shortest one I found at Tractor Suppy Co. (TSC). Around $80. I had to cut it to fit.
Bought the Weasler slip clutch from agpartz.com for $65. That website is no longer functioning. You can get slip clutches at TSC and at Agri-Supply.com.
I needed a $15 shaft extension on the rototiller gear box to position the slip clutch so it wouldn't rub on the tiller sheet metal. Bought it from Agri-Supply.
Also had to remove the short 26" long Kubota lower 3pt arms and replace them with the 35" arms from my MF-135 to make enough room for all these parts.
2010 International 4400 National Crane 300C 56FT 8 Ton Crane Truck (A50323)
2010 International...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
Kioti LK2554 Tractor (AS IS) (A50774)
Kioti LK2554...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
43013 (A51691)
43013 (A51691)
