Mowing how do I adjust my slip clutch on my rotary mower
   / how do I adjust my slip clutch on my rotary mower #1
farmacist
Saranac, New York
TC35D
I have a 10yr old Ford 951B 5' rotary mower. How do I loosen the "slip clutch"? it is a yellow (aprox 8" diameter) clutch with 4 nuts. It does not seem to slip so I want to loosen it until it slips then tighten it up again but I have both loosened and tightened the 4 bolts but it never seems to slip. Is it adjustable? These 4 bolts are the only possible adjustment showing. Sorry I'm so DUMB. Thanks Frank
   / how do I adjust my slip clutch on my rotary mower #2
It's probably stuck a little.. you'l have to loosen the bolts.. then load the pto a bit.. perhaps mow a few feet.. should be obvious when it starts slipping. .. might put a couple pipe wrenchs on it and make it slip using cheater pipes and a push pull.. 2 handed job.. etc..
No dumb questions...
Soundguy
2 Warehouse Forks (A55787)
2 Warehouse Forks...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2019 Freightliner Bucket Truck (A55973)
2019 Freightliner...
2013 John Deere 27D Mini Excavator (A55973)
2013 John Deere...
2003 International 9200I (A53317)
2003 International...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1EF7EKF89312 (A57453)
2014 Ford F-150...
