Mowing how do I adjust my slip clutch on my rotary mower
   / how do I adjust my slip clutch on my rotary mower #1
farmacist
Bronze Member
Saranac, New York
TC35D
I have a 10yr old Ford 951B 5' rotary mower. How do I loosen the "slip clutch"? it is a yellow (aprox 8" diameter) clutch with 4 nuts. It does not seem to slip so I want to loosen it until it slips then tighten it up again but I have both loosened and tightened the 4 bolts but it never seems to slip. Is it adjustable? These 4 bolts are the only possible adjustment showing. Sorry I'm so DUMB. Thanks Frank
   / how do I adjust my slip clutch on my rotary mower #2
It's probably stuck a little.. you'l have to loosen the bolts.. then load the pto a bit.. perhaps mow a few feet.. should be obvious when it starts slipping. .. might put a couple pipe wrenchs on it and make it slip using cheater pipes and a push pull.. 2 handed job.. etc..
No dumb questions...
Soundguy
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2015 Chrysler 200 Sedan (A50324)
2015 Chrysler 200...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
