How difficult is it to change the fan belt on CK 30HST?
   / How difficult is it to change the fan belt on CK 30HST? #1
Trace33
NY State
Kioti CK30 HST
Squeaks like a banshee. I tightened it once by moving alternator but its squeaking again.
   / How difficult is it to change the fan belt on CK 30HST? #2
I had adjusted mine several times over 10 years and ran out of adjustment. The belt was actually worn a little thinner, so time for a new one. It's a metric sized belt and the angle of each side is different than standard American 3L, 4L, 5L, etc. If you have a knowledgeable person behind the auto parts counter, they can match it up. For me, no knowledgeable person so I went with a factory Kioti belt. It's really not hard to change other than a few skinned knuckles. Loosen the alternator bolt. Push alternator all the way in towards the engine. Take belt off alternator, water pump, and crank pully. You'll have just enough room to work it over the fan, a few blades at a time, and between the radiator, pulling it all out at the same point/place. For me, it was on the left side. Reverse to reinstall. 2004 CK30hst.
   / How difficult is it to change the fan belt on CK 30HST? #3
It is a simple job and if it is squealing I would suggest that it has been slipping for too long and glazed the friction surface. The only option is too replace the belt and retension it after several hours running.
2003 Big Tex 10PI...
2019 GMC Savana 3500 12ft. Box Truck (A55852)
2019 GMC Savana...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2015 Autocar Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2015 Autocar...
2006 KENWORTH T800 CRANE/DUMP BED TRUCK (A57192)
2006 KENWORTH T800...
(6) ROLLS OF MISC LINOLEUM (A54757)
(6) ROLLS OF MISC...
