How Difficult Is a Fluid Tight Weld?
   / How Difficult Is a Fluid Tight Weld? #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
How likely is it that a self taught amateur like me could weld a container to hold fluid?
I'm self taught, and I'm comfortable with the structural soundness of my welds. Now, I am considering building a backhoe frame with a portion of the structural elements doubling as a hydraulic fluid reservoir. I've never tested any of my welds for "water tightness". Is this something that I could likely do or is it the exclusive territory of skilled professionals?
   / How Difficult Is a Fluid Tight Weld? #2
Weld it up and and pressure test it with air...that's what I always use...you can even use a guage to see if it drops any.
   / How Difficult Is a Fluid Tight Weld? #3
You want a continuous weld bead without gaps or porosity. If there is a leak, grind the spot and re-weld. :thumbdown:NEVER leak test with compressed air, fill the tank with water and test for leaks. NEVER, NEVER test with compressed air---BOOM!:eek:
   / How Difficult Is a Fluid Tight Weld? #4
Safety Police Alert!!! Seriously, it only takes about 10 PSI to vessel test...done it for years...if there is an explosion concern use a 5 PSI pop-off valve...I would rather take my chances with 10 PSI air than deal with the water contamination. You use compressed air to check for a leak in a tire, don't you? Not much difference if you use common sense.
   / How Difficult Is a Fluid Tight Weld? #5
As long as you're talking sheet metal and low pressures, pressure testing is fine. Every welding school in creation does it.
   / How Difficult Is a Fluid Tight Weld? #6
I'd vote against using a structural member as a reservoir regardless of your welding skills. The long-term probability of leakage due to flexation and cracking is just too high. There are lots and lots of Ford 730 and 735 loaders and other brands & types of loaders in this world with oil in the frames, and many of them weep fliud at high stress points. Once you get a crack permeated with oil, it's a chore to get it clean enough to weld up fluid-tight again.
   / How Difficult Is a Fluid Tight Weld? #7
It all depends on skill level. For some it's all in a days work. For others it may be classed in another category of weld.
In actuality its more about a proper weld than just being fluid tight for a short time.:D
   / How Difficult Is a Fluid Tight Weld? #8
A proper weld IS fluid tight. In most cases its just a case of taking the time to clean the joint and watching the puddle, not the arc. If you do wind up with a leak, grind it down instead of trying to patch the weld....
I started my welding by sticking two pieces of angle iron together to build shelves and patch broken "things" around my workshop. Then I found myself making "temperary" repairs on electric water heater tanks, the 400kw 416Volt variety that we had in apartment buildings. These were classed as pressure vessels due to their physical size and as such were supposed to be done by a licensed welder and then inspected.
In our case the building owners couldn't wait the 3 or 4 days before restoring hot water to 500 tenants so I went in with my buzz box and some 6011 to get the hot water back on that day. Then we would order a new vessel which often had a 90 day delivery
   / How Difficult Is a Fluid Tight Weld? #9
I wouldn't say there's "nuthin to it", but if you lightly pressurize the vessel (like someone already said, 10 psi is plenty) you'll be able to spaot any leaks with a bit of soapy water.
I've also used vacuum to check for air/fluid tightness, but that will only tell you if there's a leak, not where, so it's only good for checking small welds, like a pipe nipple into a tank or something.
   / How Difficult Is a Fluid Tight Weld? #10
This very important, and why I always test a welded hyd fitting with
air, as when welding a fitting onto a cylinder. I am no expert, so I do
get some micro-porosity is some of my MIG welds, detectable with soapy
water. If oil-contaminated, the weld will have to be cleaned with a
solvent to get all the oil out of the nooks and crannies.
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2004 International 4300 Box Truck, VIN # 1HTMMAAMX4H667102 (A51572)
2004 International...
2022 Harley-Davidson FXLRS Motorcycle, VIN # 1HD1YWZ11NB021297 (A51572)
2022...
2024 JOHN DEERE 331P-TIER SKID STEER (A51246)
2024 JOHN DEERE...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 84"...
