How can we jury rig
/ How can we jury rig #1
ns_in_tex
Platinum Member
East Texas
Kubota L4610 HSTC, International 2400, Hesston 1280,
We have a 30 something year old 20' bush hog mower. (so old I don't think bush hog even shows a manual) One of the U-joint yokes, I think is worn inside to the point the u-joint wobbles & shakes the drive shaft. Has any one found a way to tighten up the yoke on a 6 spline shaft without buying a new 35 series 6 spline yoke?
/ How can we jury rig #2
I’ve seen the end closest to the gearbox welded to the gearbox input shaft.
You’ll get a cussing from future mechanics if you do it though!
/ How can we jury rig #4
Can you find a slightly larger cross and bearings from an old car or truck at a junk yard and press it in ? Or can you heat it up cherry and forge it into a better fit on the cross and bearing caps ?
/ How can we jury rig #6
You might be able to modify the yoke so it's like a cathead. You would have to drill and tap four holes at each end of the female yoke and install bolts or setscrews that you use to center each end on the male spline. While it might center it, there's no guarantee how long it will keep it centered...maybe minutes or maybe hours...or more. Who knows? :confused3: :2cents: If it does work, I'd Loctite the screws in just to keep them in place. If you do decide to try this method, centering it is easiest when you use four screws per end.
Kubota MX5400 land mgmt package
Kubota MX5400 land...
CASE INTERNATIONAL 893 - 6R36" CORN HEAD (A63291)
CASE INTERNATIONAL...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
2021 Chevrolet Equinox SUV (A61574)
2021 Chevrolet...
BOWMAN WEED WICK & MOUNT (A63291)
BOWMAN WEED WICK &...
3PT BOG HARROW (A63291)
3PT BOG HARROW...
