How can I test oil pressure on John Deere 425?
   / How can I test oil pressure on John Deere 425? #1
Rob50056
Bronze Member
Springfield,Mo
John Deere lx288 and 425
I replaced cam gear with metal and had to replace oil pump gear also.The oil pump gear had stripped out also.
The oil pump gear is driven by cam gear and so is governor along with water pump.
The oil light stays on and I checked oil sending unit by removing it,reconnecting to wire then used compressed air to test it and light goes out.
Whether using air is a reliable test I do not know so Im looking for another way to test oil pressure.
The oil pump is all metal parts if I remember correctly so I can't see it failing unless gear some how stripped out again.
Is there a way to test oil pressure using outlet where oil pressure switch screws in?
I'd think an oil pressure gauge of some type might work????
I discovered the problem.
When changing the oil pump gear there is a spring that can fall out very easy and sits on top of check ball.
I double checked my work space and behold they was the spring.
I must thank this link which has a full repair manual for John Deere 425 available to download.If I hadn't seen pictures I may have missed it.
http://www.mytractorforum.com/334-john-deere/142324-john-deere-425-445-455-technical-manual.html
   / How can I test oil pressure on John Deere 425? #3
Glad you solved it. Usually I find that it's a simple mistake or something missed when a new problem arises after doing work. From the sounds of it you should get a lot more life out of your engine before needing to do a full rebuild.
   / How can I test oil pressure on John Deere 425? #4
Yep, when repairing/assembling things, there should be no parts left over !
Good Job !
Richard
   / How can I test oil pressure on John Deere 425? #5
Good Job !
Richard
No parts left over?! What fun is there in that?!:laughing:
4 1/2 150G DRILL STEM 358 JOINTS (A50854)
4 1/2 150G DRILL...
2008 John Deere 2305 Tractor (A50514)
2008 John Deere...
2024 MERCEDES-BENZ SPRINTER 3500XD BOX TRUCK (A51222)
2024 MERCEDES-BENZ...
2014 VOLVO TRUCK VN SERIES (A50854)
2014 VOLVO TRUCK...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
