How can I test oil pressure on John Deere 425?
   / How can I test oil pressure on John Deere 425? #1
Rob50056
Springfield,Mo
John Deere lx288 and 425
I replaced cam gear with metal and had to replace oil pump gear also.The oil pump gear had stripped out also.
The oil pump gear is driven by cam gear and so is governor along with water pump.
The oil light stays on and I checked oil sending unit by removing it,reconnecting to wire then used compressed air to test it and light goes out.
Whether using air is a reliable test I do not know so Im looking for another way to test oil pressure.
The oil pump is all metal parts if I remember correctly so I can't see it failing unless gear some how stripped out again.
Is there a way to test oil pressure using outlet where oil pressure switch screws in?
I'd think an oil pressure gauge of some type might work????
I discovered the problem.
When changing the oil pump gear there is a spring that can fall out very easy and sits on top of check ball.
I double checked my work space and behold they was the spring.
I must thank this link which has a full repair manual for John Deere 425 available to download.If I hadn't seen pictures I may have missed it.
http://www.mytractorforum.com/334-john-deere/142324-john-deere-425-445-455-technical-manual.html
   / How can I test oil pressure on John Deere 425? #3
Glad you solved it. Usually I find that it's a simple mistake or something missed when a new problem arises after doing work. From the sounds of it you should get a lot more life out of your engine before needing to do a full rebuild.
   / How can I test oil pressure on John Deere 425? #4
Yep, when repairing/assembling things, there should be no parts left over !
Good Job !
Richard
   / How can I test oil pressure on John Deere 425? #5
Good Job !
Richard
No parts left over?! What fun is there in that?!:laughing:
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A51039)
2022 Down2Earth...
