How can I tell if my 520 H has gear reduction front steering?
   / How can I tell if my 520 H has gear reduction front steering? #1
maytagman
Apollo, PA
wheel horse
Is this option indicated in the tractors model number, or is it by the front wheel size or front axle?
What do I look for? My front axle assembly:confused3: 008.jpg looks very wide and the steering wheel is very easy to turn.
   / How can I tell if my 520 H has gear reduction front steering? #2
I'm not sure about gear reduction steering.
I remember my 1987 WH 416-H steered a little harder than my newer 1993 WH 416-H.
I'm pretty sure they both used the same steering gear set-up, the only difference was the 1987 WH had a noticeably smaller diameter steering wheel.
I actually preferred the older, smaller steering wheel. The larger steering wheel made it more difficult to get on and off the tractor.
   / How can I tell if my 520 H has gear reduction front steering? #3
520's had both. Look at the base of the steering column and it should be clear if you have the reduction. Without it there's just a 'fan' gear. If you can post a picture I could tell you for sure.:)
Thanks!
Mine has a fan gear at the bottom of the steering shaft so it must not have the steering reduction. :)
   / How can I tell if my 520 H has gear reduction front steering? #5
Yupper dupper. Non reduction. Here's a picture of a reduction unit.
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
