How can I remove heating oil from my fuel tanks for my tractor.
   / How can I remove heating oil from my fuel tanks for my tractor. #1
lawlopez
New Boson, NH
JD X450, Kubota BX23
This is expected only if we drop power for an extended period of time.
We drop power often and I run on a EU2000i
This let's us run the pellet stove, frig, fish tanks and lights
and uses perhaps 2 gallons of gasoline a day.
If we need water we can run a tractor and PTO to bring up everything else.
If I run out of gas and diesel I want to use some of the fuel in the heating oil tanks.
But how do I get it out of my heating oil tanks ?
I can't just poke a hose down there it will pick up all sorts of junk.
The Kubota BX23 doesn't even have a fuel / water separator.
The only way I can do this now is to open up the bleed screw on the
oil furnace and run that into a tank. That will take for ever.
I have a 2 fuel oil filters and 2 tanks.
What do people do ?
My fuel supplier tells me the fuel oil is ok to use in my tractor.
The tractor is 10 years old.
Larry
   / How can I remove heating oil from my fuel tanks for my tractor. #2
My oil tanks are outside at ground level ( I use fuel treatment to prevent gelling) and my boiler is in the basement. I plumbed in a tee and a hose connection to fill my fuel cans.
   / How can I remove heating oil from my fuel tanks for my tractor. #3
How about removing one of the plugs from the top and dropping a syphone in to get the fuel?
I would zip tye the hose to a broom stick about 6" from the end to keep the hose off the bottom.
   / How can I remove heating oil from my fuel tanks for my tractor. #4
I have the fuel dealer fill a 55 gallon drum when I have my tanks filled. I keep it int he garage on a base with wheels so I can roll it around. That way I never use on-road diesel and I have enough to get me through the winter. If I buy it late enough in the year they even put anti-gel in it (just make sure you are buying off road diesel as HHO normally doesn't have it included). I have an electric pump but it would be just as easy to make a stand and put a valve in the 3/4" bung on the drum and use the fel to raise it into place. A 55 gallon drum full of fuel can be put in the back of a pickup or like I occasionally do on a very small trailer. If I don't use all of the 55 gallons in a reasonable amount of time I transfer it into the heating oil tanks.
Just thought I would throw an alternate idea out there. HHO is smelly and draining it out of the tank was going to get me into trouble with the little lady so I had to find a different solution. My plan was to replumb the vent line so I could remove a cap and drop a hose down into it and use a cheap hand pump or horrible freight electric pump to fill a jug when needed. My dealer sells off road diesel at the same price as HHO so I get free antigel.
2007 Yamaha Rhino 660 (A55218)
2007 Yamaha Rhino...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2001 Acura MDX SUV (A53424)
2001 Acura MDX SUV...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
