Tractor Sizing How big?
   / How big? #11
A kubota B series will do, except maybe round bales. I use 6' RFM and 5' tiller with my 20hp.
   / How big? #12
I'd think that 25 engine HP would be plenty. You could use more if you had it, but as you may know, that's the cutoff for the current emissions regs. Many people seem very happy with the Kubota L2501. I'd also look at the Kioti ck2610. Those are the biggest 25 HP machines that I know of. Basically they are detuned engines in a larger frame tractor than you normally see with that little HP. So, they might be a little doggy going up hills in high range, but you get a tractor with the weight to do more than a B series (for example) can handle, and you save the expense and complication of the DPF system. There may be similar models from other manufacturers, I'm not sure.
Good luck shopping and let us know what you end up with.
This. X2.
   / How big? #13
am with others 25hp min, though be nice to see you with 30HP. 25hp is still in SCUT (sub compact utilty range), and getting up to 30HP tends to get you into CUT (compact utilty tractor) range of tractors. the difference...
scut = riding lawn mower on steroids, with pure basic 3pt hitch. FEL = anything better than manual shoveling.
cut = get away from riding lawn mower frame, a heavier tractor, split rear brakes on opposite foot than the gas/go/hst peddle. more lift capacity of FEL and 3pt hitch. more ground clearance between bottom of tractor and the ground. there tends to be a bit more functions for FEL and 3pt hitch as far as valves go. and more likely more ranges / gears to choose from (instead of low/high, low/med/high) for better getting what MPH / ground speed you want.
your acreage to mow is not that big so 25hp is fine, but you have a lot of little things. maintenance wise, that will come up. and having a little more tractor would not harm you mowing, but help you with all the little maintenance of property things that come up.
your FEL lifting capacity.... if you are bring in any sort of "pallet stuff" perhaps feed for horses that comes in bags on a pallet. or you wanting to load/unload something into a truck / trailer having both FEL lifting height and capacity maybe an issue for you.
example concrete bricks, concrete bags, for the pond, any sort of lumber, moving dirt you remove from digging pond. into a dumpster. large round bails.
FEL (front end loaders) are not the best at digging, a tooth bar (strap on, bolt on) can make digging with FEL easier. but still not the best. a backhoe on tractor or better yet a mini ex or excavator much better in maneuvering and getting into areas, and just overall time spent digging and placing dirt you remove.
Koiphen.com = koi/goldfish ponds and filtration for them. head over there for your pond. read up on the many DIY builds there. along with DIY filtration.
you can get a backhoe with purchase, and tends to be cheaper if you buy... tractor, FEL (front end loader), cab, backhoe all on same receipt. but it does not sound like you will need a backhoe. and you would most likely be better off "renting" or pay someone else to dig and then do cleanup work with your unit.
many folks do the "save all the odd jobs" and then go rent an mini excavator for a weekend or like thing. some folks need a backhoe. your acreage so small overall. that you would not have any other use for an actual backhoe. and better off spending the few thousand bucks for a backhoe, in just renting a machine, and spending rest of cash on other stuff.
the exception to above. is you really do plan on DIY the entire pond yourself. including digging out the hole, running all your pipe work and digging holes for filters. if that is it. then a backhoe would more likely pay for itself. just by having it on hand when ever you got time to work on the building the pond. but even then. being able to rent a much larger mini ex (mini excavator) or larger excavator....
TNT (top and tilt) for 3pt hitch, you really do not have a long driveway, and acerage is small. so the little amount you may need to adjust the 3pt hitch lower lift arms or top link for 3pt hitch. you most likely already done, and just a little work with a metal garden rake or shovel and would be done.
you might see upper lights, on cab, sun shade, or ROPS (roll over protection system). be worth there time for you. both point frontwards and backwards.
with above said, you will most likely end up spending a descent amount of various attachments for the tractor.
a good spot for newbies = Tractor Attachments And Skid Steer Attachments For Any Tractor Or Skid Steer = watch the videos in setting stuff up and using it. to get yourself familer with what is out there.
   / How big? #14
Scrap the 100k gallon pond idea with a small tractor unless you want to spend a year on it. We just finished a 800k gallon pond. We dug at it with a 100hp tracked skid steer and a full size backhoe and full size dump truck for over a year off and on. I finally raised the white flag and brought in an excavator, dozer and two semis to move dirt. The first day in four hours they moved more dirt than we did in a year. Finished digging it the next day. Cost me 4K for the excavator and dozer and 2k for the semis. Best money I ever spent. It literally would have taken us 100's of hours to do by ourselves.
Consider a large 60"+ zero turn for the mowing. If you mow regularly and don't let it get knee high a zero turn will run circles around a tractor mowing.
   / How big? #15
Check out the 35hp Yanmar YT235. Nice machine.
Hire out the pond digging.
Get a zero turn or riding mower for the the lawn.
   / How big?
One other related question. When looking at the Landpride website they list attachments
such as a rotary tiller they specify a recommended PTO range of, for example, 15-40 hp.
If I am running it at the lower end would I just have to work slower?
In other case such as the 1648 mower it just gives a maximum engine HP.
Any special reason why they rate them differently even though they both use the PTO?
   / How big?
BTW, all the information you guys are providing is fantastic. Thanks for the help!
   / How big? #18
With a hydrostatic tractor there's really only two considerations for running an implement (within reason). Can I lift it, and can I safely traverse the ground I want to use it on. Because you can slow down to whatever ground speed you need to in order to keep the engine from bogging, you can run an implement bigger than you could with a gear tractor. So, yes, the issue with being on the low end of the HP range is speed, assuming you have enough weight for stability and lift capacity to use the implement in question.
I'm sure there's other factors too, like stressing the PTO components, but for example, the L2501 is the same tractor as the 3301 and 3901. Only difference is the engine. So, if I had a 3901 and you had a 2501, we could both use a 6' bush hog, but I could power through and cut faster in thick grass which might cause you to slow down. On 30 acres that might be a big consideration, but on a smaller lot it might not be. For that matter, if the field is bumpy, we're both gonna be going slow anyway.
   / How big? #19
Well said
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A56857)
2025 GIYI GY-ZWB...
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
TANK MANIFOLD (A55745)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
