How big of tractor?
   / How big of tractor? #1
IowaGuy
Woodward, Iowa
1949 M Farmall
How big of tractor do I need to maintain my 5 acres. It's mostly flat. We have horses and I would buy a backhoe to build a bridge across my small creek. I also need to mow the grass with it. I like the 3054 and the DK35. Are these big enough? Is the extra 5 hp worth it? I have been researching and like what I see with the Kioti. I also have a 1949 M Farmall we tinker with, but it is big and hard to manuever. Thanks for the help!!
   / How big of tractor? #2
Either one of these tractors will do want your planning,if your going to be mowing lawn I would not get Ag tires.
I have a DK35 and it is super!!
   / How big of tractor? #3
This question is asked probably as much as "What do you think...." questions. Based on what you intend to use it for, I'd say the common answer would be anything between 25 hp and 35 hp would suit you just fine. You'll also find, however, that the other frequent comment is to get the most hp that you can afford, because it always seems like people find more uses for their tractors after they get them, and you never hear anyone saying they wish they had less hp.
   / How big of tractor? #4
I am a big fan of bigger is better. How big is the biggest vehicle you need to pull from a ditch? This is what prompted me to buy a large tractor. I have a full size 1/2 ton pickup and a fairly large ditch. I didn't buy a Kioti, but if I'd known of them, I probably would have.
Tester
   / How big of tractor? #5
I also agree that generally bigger is better.
With only 5 acres the 30hp or the 35 hp would do just fine but you could also be allright with the 25hp.
All of these will handle 5' equipment without any problems but the DK would handle even 6' Boxblade or mower without a problem.
I vote to get the biggest you can afford and use on your place.
JMHO,
Mr. Kioti
   / How big of tractor? #6
my 3054 cuts waiste high field grass/hay with a 6 foot brush hog, without hesitation. very impressive machine
2002 MANAC 48'  WALKING FLOOR REFUSE TRAILER (A53426)
2002 MANAC 48'...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
UNUSED AGT TSOCPF48 MAST W/ 48" FORKS (A51248)
UNUSED AGT...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2021 JOHN DEERE 8R 370 LOT IDENTIFIER 222 (A53084)
2021 JOHN DEERE 8R...
UNUSED RAYTREE RMSG-29 29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
