How big of cylinder do I need?
   / How big of cylinder do I need? #11
With the rake square to the boom I marked a point on the 3pt frame and on the rake frame and swung the rake to 45º left and right.
I need 27" short and 36" long. So a 9-10 inch stroke would do.
A few pictures of your rake would really help. There are various designs for this stuff. It sounds like you have a short boom if you are looking at using the 3pt hitch mount as a base mount for the rake angle cylinder mount.
A std clevis end welded cylinder with a 10" stroke is 20 1/4"- 30 1/4"
A 12" unit would be 22 1/4"- 34 1/4".
Sounds good - I'll post pics in the AM. Thank you
   / How big of cylinder do I need? #13
Any pics yet Or decided on what cylinder to use?
Sorry for the delay. A snow plow application sounds similar. FYI I tried the rake on the gravel road and I liked it vs the box blade. So I will pursue this mod.
Nvrmnd the wheels pictured. I'm in the process of putting on some larger adjustable gauge wheels. The BH rake is 84 inches
   / How big of cylinder do I need? #16
The closer to center you mount the cylinder on the rake the shorter the stroke can be. Can you find a pair of single acting cylinders from an old snow plow and mount one on each side and operate them like one DA cylinder.
I finally pulled the trigger on a double action 3" x 1.5" rod cylinder with a 12" stroke and 1" pins
Product Details​
The Chief 3 in. Bore x 12 in. Stroke WC Welded Cylinder is a high-quality welded hydraulic cylinder with a strong forged steel base. Made for when space is limited, this hydraulic cylinder model has a screw-in gland that reduces the cylinder profile by replacing the collar style gland. It will provide added strength to agricultural implements, compact construction and transportation equipment, as well as waste/recycling applications, and the base end clevis extends out 2 in. to ensure greater swing radius and maximum flexibility.
  • Intended use: double-acting applications
  • Piston: ductile iron
  • Gland: ductile iron
  • Tube: precision-honed steel
  • Rod: hard chrome-plated
  • End mounts: ductile iron female clevises with pins and clips included
  • Tube seals: Buna O-ring
  • Rod seal: deep polypak with B-lip design
  • Rod wiper: urethane, snap-in
  • Piston seal: Hallite 755 for prolonged wear resistance with wear ring
  • All seals: manufactured to US specifications
  • Functionally tested and pressurized to 1.5 times the normal working pressure to ensure performance reliability
  • Welded hydraulic cylinder with SAE O-ring ports that allow for easy hookup
  • Has a 3,000 PSI operating range
  • 3-year limited warranty
  • Measures 20.25 in. retracted and 30.25 in. extended
  • Individually poly bagged hydraulic cylinder is easy to transport
  • Column load: 21,200 lb.
  • Pin diameter of 1in. and rod diameter of 1.5 in.
This thing arrived and all I can say is this cylinder is huge! 3" looks like 2 times overkill. 1/2 lines? Can I run 3/8ths lines There really is no load turning the rake on it's pivot.
What do you all think. Will 3/8ths lines about 4ft long from the quick attach be okay?
   / How big of cylinder do I need? #19
The smaller the lines, the slower the cylinder will respond.
IIRC, I used 1/4” lines on mine but the cylinder bore was smaller (maybe 2” ?) than the one you’re using.
Mine was plenty fast enough.
Thanks for your reply. Right now I'm thinking 3/8 lines
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
2006 Peterbilt 379 T/A Sleep Cab Truck Tractor (A49461)
2006 Peterbilt 379...
2019 JOHN DEERE 317G SKID STEER (A51242)
2019 JOHN DEERE...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
