how big of a tiller can you run on a 2920?
   / how big of a tiller can you run on a 2920? #11
You've already broken the ground with a plow, and the B2920 is no sloutch on power for it's size, so I'd bet it would do just fine ...
... provided you don't try to till down to China or try to finish it in a big hurry.
Slow ground speed (< 1 mph) & medium depth ( 3 - 4" ) should give you good results.
No need to fret about covering your tire tracks, either.
   / how big of a tiller can you run on a 2920? #12
I run a 48 inch tiller with my B2620. Works great. Could go bigger. With it plowed I would try it. You'll know soon enough. Btw you don't turn with it in the ground.
I wouldn't buy one that big for it but you have an opportunity to try it.
   / how big of a tiller can you run on a 2920? #13
I plan on getting a 60" for mine next spring. Why not give it a shot and let us know how it works out. Think slow and shallow.
   / how big of a tiller can you run on a 2920? #14
60" on a b2630. Don't even know its back there.
   / how big of a tiller can you run on a 2920? #15
60" king kutter II tiller on BX2370-1, no problems. I already had the tiller though and have a larger tractor as well.
   / how big of a tiller can you run on a 2920? #16
Rotary tillers and rotary cutters both like five (5) PTO horsepower per foot of width. The shock load of a too large cutter or tiller on the PTO drive system could have one asking a dealer why the costly repair he is talked about is not covered by warranty.
Rotary tillers and rotary cutters both like five (5) PTO horsepower per foot of width. The shock load of a too large cutter or tiller on the PTO drive system could have one asking a dealer why the costly repair he is talked about is not cover by warranty.
I have heard this before....but the b2920 has 21 pto hp, so that means a 48" tiller/rotary/snowblower(I have heard the same measurement there as well)?
it seems like "everyone" runs a 60"-64" snowblower on their B series and a lot of people in this thread are running more than 4' tillers on B series or even smaller BXs...where does this rule of thumb come from and who has seen that limit demonstrated (seen a tractor fail to run something over the 5hp/foot or break when trying to do so)?
Also, the shockload you are talking about would only apply if engaging PTO with the implent engaged right? (like with the tiller in the ground)
   / how big of a tiller can you run on a 2920? #18
I was thinking of tilling along and all of a sudden the tines encounter a large rock, or hard packed soil. I have seen tillers stall tractors before. Shear bolts and slip clutches are a must have item when using a tiller or a rotary cutter or any other PTO operated tool. The PTO is going to try to keep spinning regardless if the implement has stopped and the weak link in the chain is usually what breaks. It is an expensive repair when it is in the PTO, drivetrain system. The one extra foot of width will not save that much time if you have to crawl along to use it.
I personally use five horsepower per foot of width. Of course that is for my equipment. I believe a person should use whatever size equipment he wants too. After all, it is their tractor and they are the ones responsible if something breaks, not me.
   / how big of a tiller can you run on a 2920? #19
Shock loading or rather preventing it is the job of the slip clutch. I don't know of any tiller that doesn't have one. As for power, I don't find that they take a lot of power to turn the tines. I think the only limitation to a reasonable size would be the weight. If you look in your owners manual they should state the maximum weight of a 3 PH implement. This it not the lift capacity but rather the weight that the tractor can safely handle. I know that my Kubota B26 could not handle the weight of a 72" tiller (I think 48 or 50" was stated as max) so I decided that I would put one on my 70HP tractor instead.
   / how big of a tiller can you run on a 2920? #20
Recently bought the 58" Land Pride for my B2650 - kinda wish I got the 66". Don't even know there's a tiller back there right now, and feel as though it would handle a 72" as well. It may be a little harder on fresh ground break, but you typically only do that once..... Maintaining a tilled plot is easy.
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
Vermeer SC802 (A50322)
2018 John Deere 331G Compact Track Loader Skid Steer (A50322)
2018 John Deere...
2020 CATERPILLAR 242D3 WHEELED SKID STEER (A51242)
2020 CATERPILLAR...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
