Mowing How big of a disk mower?
   / How big of a disk mower? #1
MMG
Branson 4720
I have a Branson 4720 (47hp/42pto), will it handle a 9 foot disk mower ok?
   / How big of a disk mower? #2
I would think not. Most manufactors of disc mowers have the spec's on the websites to match PTO HP to the mower.
I am shopping for another disc mower and my Branson is 55 hp ... I think 48 at the PTO.
I found one Mfg ... Haymag that said yes on the 9' cutter but recomended I not do that.
   / How big of a disk mower? #3
No 9 ft, I would suggest a 7 ft (5 rotor) on hilly fields and maybe a 8 ft (6 rotors) on flat fields. Our New Fort 7 ft sell for $5795 and the 8 ft $6295. We have sold almost 1000 of these units in the last 15 yrs or so. Ken Sweet
   / How big of a disk mower? #4
The Fort Model 2050 states 45 hp in the spec's ... and the 2060 states 55hp. I assume thats tractor hp not pto?
   / How big of a disk mower? #5
For that small of a tractor I would stay with a 7' mower or go to a sickle bar mower inwhich u could use a 9' just depends on how much u are wanting to cut.
   / How big of a disk mower? #6
Blueriver have u looked at the vicon 3 blade mowers. I have alot of customers who are verry please whith this product. Also if u put the mower on a caddy u can get away using it on a smaller tractor. It make hook up alot easier also. I have one on all 3 of my mowers
   / How big of a disk mower? #7
A 45 hp tractor can turn a 9 ft, however, the Mfgr. specs are looking more at the weight and "Stance" of the tractor for safety's sake. We have in stock the new Enorossi 7 ft double action sickle mowers with hydraulic lift kit for $3695. My Shop Foreman has a disc mower and one of these double action mowers and the double action will make a round every time the disc mower does. Damp hay don't matter. Ken Sweet
   / How big of a disk mower? #8
I have considered them ... just have yet to get a $ quote. I am not much on the Caddy only because a couple of my fields I load and haul the tractor and cutter.
If your asking because you sell them fire a quote over by PM ... I want to match the PTO HP to the cutter. The tractor is 55 Hp with I believe 48 at the PTO.
   / How big of a disk mower? #9
If you like Vicon 3 blade per disc design and don't like the Vicon high prices, we have the new Superior 6 head disc mower with 3 blades per rotor for $6295. Ken Sweet
I just found this searching around. Anyone familiar with em?
ITEMS DETAILS & MODELS PRICE US$
HayMAG
(Made in USA)
Lely Style
CCM-165- 5'5"cut Shaft Drive- 800 Lbs. 22 HP min.
(works on compact tractors with rear exterior hydraulics) CALL
CCM-205- 6'9"cut- Shaft Drive- 950 Lbs.- 30 hp minimum CALL
CCM-240- 7'10"cut -Shaft Drive- 1050 Lbs- 36 HP minimum CALL
CCM-280- 9'2"cut- Shaft Drive- 1150 Lbs- 42 HP minimum CALL
The HayMAGNUM Shaft design has 1/3 less moving parts and requires 20% less PTO HP to operate than a conventional oil bath style disc mowers. Lely style cutterbar
The HayMAGNUM Spring Steel hex drive shaft that acts as a shock absorber
Cutting units are grease filled for long life and low maintenance, elevated operation all day without starving the cutterbar for lubrication
Individual cutting heads require less down time to repair.
Safety lock in transport position
Heavy duty one piece curtain for safety and extended life
Unique Heavy duty blade disc with a simple, safe & cost effective design.
Simple blade bolts, No costly blade mounting hardware as other manufacturers.
Light weight design for use on smaller & more fuel efficient tractors. SAVES FUEL !
Powder coated paint for long life.
Replaceable skid shoes
Safety release avoids damage from objects
4 belt design for long belt life
CAT 1 & 2 hitch available on all models
MADE IN THE USA
42013 (A51691)
42013 (A51691)
Dry Gel Hydration Unit (A53843)
Dry Gel Hydration...
2019 Hustler X-One 60in Zero Turn Mower (A51691)
2019 Hustler X-One...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
2025 AGT MX-CRT23 (A50123)
2025 AGT MX-CRT23...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
