Rear Finish Mower How big is too big? rear finish mower 7',8',9'+
   / How big is too big? rear finish mower 7',8',9'+ #11
Re: How big is too big? rear finish mower 7\',8\',9\'+
Brent,
My Mahindra 3510 is 35hp and handles an 84" RFM quite well up to about 10th gear (of 12 total). I had to modify it somewhat because it is CAT-II and my tractor and quickhitch is CAT-I.
I don't know the specs of your tractor, but this should give you an HP to RFM size idea.
Also, consider how flat your ground to be mowed. If uneven, it can scalp pretty easily and may overwhelm the antiscalp roller, leaving scrapes in the grass where the roller was- especially when damp.
-JC
   / How big is too big? rear finish mower 7',8',9'+ #12
I have a 90" flail mower on a 48hp tractor. The only downside of increased width is that you will scalp crests and the grass will be longer in troughs because the mower doesn't conform to curves.
   / How big is too big? rear finish mower 7',8',9'+ #13
I run an 8' mower with my IH 484 with about 45hp at the PTO. Works really well and cuts 5 acres in less than 2 hours. It can bog down occasionally if the grass is a bit long, but going slower helps that. I wouldn't get a bigger finishing mower, but I'd love a 10 or 12' gang mower if I could afford one!
   / How big is too big? rear finish mower 7',8',9'+ #14
If your land is flat wide is ok, but if hilly like mine I found that my 72" over the 60" I had will do a lot more scalping.
murph
   / How big is too big? rear finish mower 7',8',9'+ #15
I have a kubota b2910 with 23 hp at the pto. I run a 72" rfm. I have a hilly lot. The hp is suited to the mower and works for me.
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
HORSE ROPING SADDLE W/ BLANKET (A58376)
HORSE ROPING...
LOT: Custom Built Model Construction Site - Includes All Toys on Top & Inside: (13) Toys on Top, (A59076)
LOT: Custom Built...
JOHN DEERE 6000 SERIES BRUSHGUARD (A58375)
JOHN DEERE 6000...
2016 Sun Coastal 16' Cargo Trailer (A57148)
2016 Sun Coastal...
2019 INTERNATIONAL LT625 (A58214)
2019 INTERNATIONAL...
