How best to kill one thing growing right next to another?
   / How best to kill one thing growing right next to another?
Why mix with diesel? I'm not doubting, I basically know nothing about herbicides - just curious.
   / How best to kill one thing growing right next to another? #12
The fuel helps to drive the herbicide into the cut stump and the oil in the diesel seals the herbicide into the stump.
   / How best to kill one thing growing right next to another? #13
Willows are really resilient, with only part of the roots in the ground il will sprout back, keep cutting it is my suggestion.
   / How best to kill one thing growing right next to another? #14
Cover you fig with a plastic bag and soak your willow with a mix of roundup/2,4d, diacamba. Buy all ingredients individually if you can so you can use high rate of each. Soak as soon as dew off in morning and leave fig covered for the day. Next day uncover fig.
I know there will be some on here that will doubt this method. You will only kill what is green and liquid touches. If in fact willow roots are from a main tree. You will not kill the main tree.
   / How best to kill one thing growing right next to another? #15
Have you thought about moving the fig??
   / How best to kill one thing growing right next to another? #16
I do not use chemicals. My wife has an extreme sensitivity, my property is a watershed for a nearby lake, and after attending a forestry seminar on proper application (right time, right chemical, right delivery method) I decided it wasn't worth it.
I did successfully eradicate Tree of Heaven from my forest. It took a lot of persistence and recutting over a period of years. So it can be done.
Looking at the picture. I would weed eat that area down as close as I could get it and then keep watching for shoots to come up. Basic plant biology as I understand it, says there has to be stuff above ground to sustain a root system. If there is nothing above ground the roots have to die eventually. So my thought is that some of the shoots are sneaking up in the tall grass and that is contributing to your problem.
Good luck.
Doug in SW IA
It's a moot point, that's hardly the only willow in the area and they're spreading. I could move the fig, but sooner or later I'd have to move the quince, the cherry tree, etc.
Good luck.
Doug in SW IA
I've basically done this with blackberries here, but they're a lot easier. Truth is when I've dug & cut this stuff (around the fig and all around the shed as the roots are under the shed and it sprouts all around), I haven't been diligent enough to keep it from coming back.
   / How best to kill one thing growing right next to another? #19
You must mow the field there. Just mow over it every time you mow. The fig will eventually crowd it out, you could also put an upside down bucket over it after it’s cut to sun deprive it.
   / How best to kill one thing growing right next to another? #20
I think the phrase is “kill them all and let God sort them out”. Does that work for plants?
1997 HUBBLER BROS. LOGGING TRAILER (A50854)
1997 HUBBLER BROS...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
377811 (A48836)
377811 (A48836)
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
48in Forks Loader Attachment (A49346)
48in Forks Loader...
3 pt Aer-Way (A50514)
