How best to kill one thing growing right next to another?
   / How best to kill one thing growing right next to another? #1
ning
Elite Member
Northern California
Branson 3520h
I have a willow that refuses all requests to die, growing right next to this fig.
Willows are also growing nearby.
I'd prefer that the willows grow elsewhere, which they already do, but these won't leave.
How can I get rid of them, without harming the fig? Digging and pulling has failed, so far.
   / How best to kill one thing growing right next to another? #3
On localized applications like this, you could use a small paint brush to apply Roundup to the undesirable plants.
The only problem is that Roundup is systemic so if the roots of the two plants are intertwined it could also kill the fig.
Try stump treating the willow with Lux dish detergent, or a high acidity vinegar.
So cut it and paint with high acid vinegar?
I've heard of people trying that with blackberries, put a cut end in a jar of vinegar
   / How best to kill one thing growing right next to another? #8
If you don't have other willows close by, aggressive cutting will deplete the resources in the root system, but you will need to keep cutting it frequently. Crushing the remaining stem into fibers helps the plant abandon growth at that site.
Have you tried cutting the stems it below ground 2-3", and then covering the local area with a metal can?
If the fig isn't too special, I might try trying to pull the willow, but I think it has real risks to the fig.
All the best,
Peter
I dug all around that area pulling what I could before putting the fig in. I think there's root system coming from under the slab of a shed about 8' away.
   / How best to kill one thing growing right next to another? #10
Cut it and paint the stump with 2-4-D mixed in diesel. It’s unlikely that trees of a different genus would have root grafts. But if the willow is a root sprout from another willow tree, you will kill them both.
JOHN DEERE 450H CRAWLER DOZER (A51406)
JOHN DEERE 450H...
2014 CATERPILLAR 336FL EXCAVATOR (A51242)
2014 CATERPILLAR...
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A49461)
2014 Peterbilt 320...
Ranch Hand Pickup Truck Grill Guard (A49461)
Ranch Hand Pickup...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
