How best to excavate this stump?
   / How best to excavate this stump? #21
I have a few (stupid?) ideas. I see foliage on the left, is the right ok or dead? It looks like the trunk and root system is ok...what about grafting onto it?
I would be tempted to save it.
   / How best to excavate this stump? #22
^^ Yeah, we haven't really asked about condition. If it's hollow and full of ants, beetles or termites, that scraps most of the ideas. It could break up and come out pretty easy.
   / How best to excavate this stump? #23
I don't know your time frame on removal, but why not cut it down to close to ground level and burn it up. It should burn fairly easy if it is almost dead.
   / How best to excavate this stump? #24
Doesn't a one foot DBH tree require a good size hole to plant?
Dig the stump, add a little dirt and plant the new tree.
No, the upper stump will not be solid wood. There's a water seep and rot split down the middle of the other side.
   / How best to excavate this stump? #26
I'd get a local qualified Arborist to look at the tree and see if he or someone he knows has a large, fairly new stump grinder with sharp teeth. Have the tree cut down, you or someone else cut it flush with the grade. Have stump grinder cut until you can break out what remains with your hoe, or mini-ex rental, borrow?
Plant a new specimen tree with the correct mix of soil for it to take to the ground before winter.
Done.
   / How best to excavate this stump? #27
I still recommend C-4 plastic explosive if you can round some up. The beauty of this method is that if you use enough, you will probably not have the stump still on your property when you are finished. Kill two birds with one stone..... :)
Bang. Zoom. Straight to the Moon!!!
One of these days.
   / How best to excavate this stump? #28
That actually looks diggable to me. But maybe the photo is misleading.
   / How best to excavate this stump? #29
Just dig it out with your hoe. If it has a spreading root structure you may have to dig around them and cut them off to avoid the pavement but you can do it with some time and care.
JOHN DEERE 4440 TRACTOR (A54756)
JOHN DEERE 4440...
22ft Rollback Flatbed Body with Winch (A54814)
22ft Rollback...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2021 CATERPILLAR 299D3 XE SKID STEER (A52705)
2021 CATERPILLAR...
UNUSED FUTURE D680 HYD PILE HAMMER (A54757)
UNUSED FUTURE D680...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55301)
UNVERFERTH 330 -...
