How best to dam a creek?????
   / How best to dam a creek????? #81
I have. I have also had them constructed on the property by professionals with the conservation service. There are good sources out there on how to build dams in many designs and technologies.
All the best,
Peter
   / How best to dam a creek????? #82
Actually I was thinking that if the pond had inflow it would also have outflow which would keep the water fresh.
I'd use the flow of the ditch to power a small pump to aerate/circulate the pond if I go this route.
   / How best to dam a creek????? #83
I’ve helped build dams, mainly inspection and material testing. These were engineered and permitted dams. The op has already shown he just wants to do it off the cuff. There are plenty of ponds built around here that weren’t permitted.
   / How best to dam a creek????? #84
Ok, mythical imported beavers aside, who here has ACTUALLY constructed a dam?
Sounds like basically no one, lotta dreamers (like myself) and folks who inherited one that was already constructed. We need some DIY examples
“mythical”?
Ain’t no myth around here….we have to have a heart trap them and get rid of them.
   / How best to dam a creek????? #85
I'll figure it out...disregard...
I think that sealing the dam to the rock stream bottom might not work out. This is from talking with lots of pond owners and builders warning me about paying strict attention to (just) my outlet pipe. Hydrostatic pressure is difficult to deal with, ask anyone with a wet foundation.
Good luck and ask around locally about this concern.👍
   / How best to dam a creek????? #86
For a fairly simple, and semi permanent small dam in a creek, it's pretty simple. If we want something like a 0.5 acre + pond, or significant height to the dam, we simple lack the info needed; Soil types, bottom of the creek material, rain fall, water shed, down stream hazards, ect.
When we start getting to say, the 250,000 gal capacity, that's approx a 50 ft x 50 ft square, 48" deep, I would be more worried about the 50 year rain, and similar. When we are talking about the equivalent of a large walmart 20 ft diameter, 54" deep, package pool, we can relax.
   / How best to dam a creek????? #87
Yeah, our 24' round above ground is about 13,000 gallons. I've seen it burst (moles undermined it) and it lost all its water through our garage and out the front in just a few minutes. But little damage overall.
   / How best to dam a creek????? #88
“mythical”?
Key word being "imported". I'm rather skeptical that one can unload a beaver and convince it to dam a certain spot.
   / How best to dam a creek????? #89
Be positive.
Never know till you try!
   / How best to dam a creek????? #90
So, I did all of 60 secs of research on allowable use of water; and needless to say, it's Extremely dependent on state/local laws/regs; but the short version is, abutting property owners generally have the right to use "reasonable" amounts of the water. Reasonable might be less than 250,000g/day in some areas, and might be a single gallon in others.
Non of that is to say it's unregulated use, and also non of it is to say you should or should not build the dam.
CAT 312C (A50854)
CAT 312C (A50854)
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2014 KENWORTH T800 SLEEPER CAB (A50854)
2014 KENWORTH T800...
2015 PETERBILT 367 HOT OIL (A50854)
2015 PETERBILT 367...
2022 Wacker Neuson SM100 Mini Skid Steer (A51039)
2022 Wacker Neuson...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
