How best to dam a creek?????
   / How best to dam a creek????? #41
In Wyoming the best damn builders are tumbleweeds.
I know because this spring I removed tons of them plugging up the water to my lake.
NRCS doesn’t have agents and they don’t come to your property without you calling and asking them to come. They are a technical service arm of USDA and have technical specialists. Most large farms and ranches are familiar and use them for technical assistance to provide project plans and recommendations. They don’t tell anyone what to do; they listen to what you want and provide ideas. But you can always guess about the hydrology or maybe pay a consulting hydrologist instead of using their free advice. Your choice.
My choice is not making a major production out of simplicity. Been there done that...one phone call away from h*((.
At my homeplace is a 2 ac. lake my grandfather had put in 1954. 18ft deep at overflow pipe. It has a 4ft culvert one side of dam about 3ft above drain and spillway other side a few feet above culvert.
After lake was put in he said it's going to take forever to fill then Hurricane Hazel hit that night and filled it. The famous flood of '69 water went over the dam, lake was about 4 acres and dock and picnic area under water.
It's been dredged a couple times and now lily pads are starting to grow over it. It's probably 6ft deep at overflow pipe.
   / How best to dam a creek????? #46
Are Beavers found in your part of the country?
Here, in mine, they do an amazing job of dam building.
No permits, studies, or gubmit types 🤡 tromping around on your property needed
   / How best to dam a creek????? #47
I have a spring I hope to have dug out next year. My plan is to have somebody come in with an excavator and work for a day. That will determine the size and depth.
It will be $1200 well spent
No permits, studies, or gubmit types tromping around on your property needed
We do have beavers. How I would get them to build where I want is beyond me.
At the homeplace beavers got into the lake about 30 years ago and what a mess...they first cut down all the nice trees we planted around the edge then dammed the inlet stream creating a big swamp area. My Dad let a hunter shoot them.
   / How best to dam a creek????? #49
Exactly. I've seen a 30" pipe washed 50 yards downstream in a little trickle stream which didn't even have water during the spring thaw. Hydraulic pressure is impressive.
I have FOUR 4' culverts under my creek crossing. Normal flow is about 6-8" through ONE culvert. During real heavy rain event the culverts can not contain the flow and the hayfield becomes a 2-3 acre pond until water crosses the my driveway at a designed low spot.
Pond has a 20' wide 4' deep spillway before the 120' wide emergency spillway comes into play. I've seen almost 3' deep water coming over the emergency spillway.
Granted we can get some heavy storms and are in hill county.
   / How best to dam a creek????? #50
Beavers seem to only build where you don't want them and eventually will drop any tree you would like to have. I have lots of practice removing the those critters and their works.
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A49461)
2022 Ford F-250 XL...
Pump Jack With Battery (A49461)
Pump Jack With...
1984 Trailmobile Enclosed Van Trailer (A51039)
1984 Trailmobile...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2022 Ram Bighorn 2500 4X4 (A51039)
2022 Ram Bighorn...
