How best to clear shallow roots and vines and fern
   / How best to clear shallow roots and vines and fern #11
rent
   / How best to clear shallow roots and vines and fern #12
i tried using the toothbar, but with the uneven ground, i kept digging into the ground instead of an even scrape over the surface. Maybe i just need more practice:)
I'm afraid you'll either bend something on your FEL or damage your hydraulics because that's what can happen due to the uneven ground, stumps, roots and rocks. This is why some have suggested using a rear field cultivator with spring teeth that have some flex to bend and are spring mounted when you hit something in the ground. Even if you break a tooth, that's less expensive to repair than tearing up your FEL or hydraulic system. You can also lift it up with your rear 3pt hitch to clean the vines off if they don't slide off on their own.
I was starting to think about a rear spike harrow pulled behind the tractor. It's own weight holds it to the ground and it is free to move up and down on its own because it's pulled with a chain. It's going to follow the ground contour of its own accord, but the spikes should tear into the vines. The difficulty would be that the spikes will load up with vines and would be a pain to clean out.
   / How best to clear shallow roots and vines and fern #13
hire a local farmer with a disc to turn the top layer of soil a couple of times.
   / How best to clear shallow roots and vines and fern #14
I can tackle all that with a riding mower and a two bit axe.
is there an attachment similar to the box blade’s scarifier that i can pull to rip shallow brush out? I noticed box blade usually has 3-4 tines. I am hoping for more closely spaced heavier duty tines than on the landscape rake.
   / How best to clear shallow roots and vines and fern #16
Fred Cain cultivator
   / How best to clear shallow roots and vines and fern #17
i have a toothbar on my bucket, stump bucket. I have attached a few pic. Most volunteers are from holly, hazelnut and poplar variety. The numerous ferns are everywhere
I have been fighting kudzu vine for years. There was a point where I tried one of the walk behind string trimmers that uses the very heavy duty line. I was surprised at how effective it was at shredding kudzu vine because it's a pretty tough vine and because it runs low to the ground beneath where most mower blades can reach.
Since the kudzu was on a steep bank and the walk behind trimmer wasn't self propelled, I sold it because it was tiring to use. It was effective on kudzu vines, however. The vines were rough on the trimmer line and they had to be changed frequently.
Having said that, I suspect you could use a walk behind string trimmer or at least try a very heavy duty string in your gas trimmer to see how effective it might be.
If the area is just too big to use a trimmer, are their any used rear mount field cultivators for sale in your area?
   / How best to clear shallow roots and vines and fern #18
Read Post #3.
Thanks, I will look for those type of plows, hopefully some rental yard has something similar. It is a bit spendy to purchase right now.
   / How best to clear shallow roots and vines and fern #20
Would a landscape rake be able to rip shallow roots
It may but it will only rip up one end of the root. You will still need to go back through with a set of loppers to trim. Removing every other tine helps too.
2011 Ford E-250 Super Duty Cargo Van (A55852)
2011 Ford E-250...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
2025 Spirit 48 48V 1000W All Terrain Electric bicycle (A55758)
2025 Spirit 48 48V...
Gulf Vintage Decorative Fuel Pump (A55758)
Gulf Vintage...
