Buying Advice How bad is no 3 point?
   / How bad is no 3 point? #41
They have wheels, you can pull them forward orpush them while backing up.
As far as switching implements back up drop in a draw pin hook up a couple of hydraulic hoses if needed a PTO shaft with plenty of room to get in and around, no squeezing around fumbling through 3 point arms and linkages.
   / How bad is no 3 point? #42
They are quite common on the new large implements and they were quite common years ago on smaller implements for the little Ford's, Massey's, Farmalls and JD all the manufacturers had them and still do.
   / How bad is no 3 point? #43
I think you guys have forgotten what he needs a tractor for. He has 5 acres and wants to maybe work an acre. any 25 to 30 hp 4x4 tractor with feL will be more than enough. A 5 ft tiller will do the job just fine.I have 3 or 4 pull type implements but i also have at least a dozen that are 3 pt. They both have there place.
   / How bad is no 3 point? #44
As far as switching implements back up drop in a draw pin hook up a couple of hydraulic hoses if needed a PTO shaft with plenty of room to get in and around, no squeezing around fumbling through 3 point arms and linkages. You'll never need a quick hitch either.
Fixed that for ya. :rolleyes:
   / How bad is no 3 point? #46
We have modern tractors without three point hitches, BUT they also have plenty of hydraulics to make up for the ability to lift.
I thought $3000 for a tractor without a 3 point hitch or a Front End Loader was kind of a high price unto itself.
Versatility is what makes the farm tractor what it is. Buying a tractor without a 3 point hitch or a front end loader is like buying a house without a kitchen or a bathroom.
   / How bad is no 3 point? #47
Up here we call that a "shed".
   / How bad is no 3 point? #48
up here, a 3point is not considered a necessity, rather than anything a detriment ... but most people here farm a section or better, and don't see the need for 3point stuff ... and for large farms only one tractor would be ridiculous ..
the OP with 5 acres and only wanting one tractor, should look at what's available for equipment that he will use, available in that area, before making up his mind about that tractor ..
   / How bad is no 3 point? #49
day's? I've been from a brinly 10" to 20+' equipment. if it takes days to plow an acre, you forgot to put fuel in your tractor
   / How bad is no 3 point? #50
besides that, the 2020's around here have been known to be abortions
Towable Chemical Applicator Sprayer (A59228)
Towable Chemical...
RING 2 STARTS HERE @ 9:15 AM (A60430)
RING 2 STARTS HERE...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2017 Bobcat T770 Compact Track Loader (A56438)
2017 Bobcat T770...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2019 CATERPILLAR D6 HIGH TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
