How bad is it to just put-around at slow speed?
   / How bad is it to just put-around at slow speed? #1
dukenyc
Upstate NY
JD 4100
I know this may label me as a wimp, but most of the time my rhino will be going 5-15mph. I am going to be riding in tight woods, so high speed isn't an option. The are is VERY hilly and the engine breakign was a big factor in my decision to go with the rhino.
Is it bad for the clutch/cvt/engine to run these things really slow up and down hills 90% of the time? would it be better for the machine if I used low gear? It has plenty of power in high gear, but I am barely rev-ing the engine at all much of the time.
   / How bad is it to just put-around at slow speed? #2
Sometimes the engine will get loaded down with unburned gasses and carbon up the plugs if idling a lot of the time. Either way, revving up once in a while, or just plan on replacing the plugs more often are solutions. No good formula to go by, but I think you are pretty aware of that it might not be the best for the engine. Its yours to enjoy the way you like to enjoy it, IMO.
   / How bad is it to just put-around at slow speed? #3
It will last at least three times longer than the idiots who run them wide open all the time.
   / How bad is it to just put-around at slow speed? #4
just going by my atv experience, if you are going slow, it is better to keep the trans in low. the belts can burn up pretty quick if you are not careful. since the sheaves move by centrifugal force, it is best to keep the engine revved up a couple thousand rpm, versus just over idle.
   / How bad is it to just put-around at slow speed? #5
When I'm just putting around at slow speeds, I generally move mine on up into "L". This seems to be easier on everything especially when putting up a hill. Yes, I am quite aware that the Rhino will pull most hills in high range, but running at slow speeds seems to be easier on everything when in low range. Either way, I don't think you'll kill it.
   / How bad is it to just put-around at slow speed? #6
duk - I have a 1984 Big Red 3 wheeler and have been driving it at slow speeds for 21 years and it's still going strong - infact several people have wanted to buy it - about 650 miles on it. It's something like an old friend - don't get rid of those either. Can't hurt it by driving slow in a low gear.
penokee /forums/images/graemlins/smile.gif
3419 (A57193)
3419 (A57193)
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2021 Deere 333G (A53317)
2021 Deere 333G...
2023 John Deere 8RX 370 Track Tractor (A53485)
2023 John Deere...
2023 John Deere 333G for Parts (A57024)
2023 John Deere...
