Mid-Mount Mower How are you guys lifting a mid mount mower upright for winter storage
   / How are you guys lifting a mid mount mower upright for winter storage #11
   / How are you guys lifting a mid mount mower upright for winter storage #12
I have a chain fall hanging from barn track that runs the width of my barn. First, I pick it up with that, then set it on this:
With casters that swivel a full 360° I can move it very easily, in any direction, one end or both ends. Much handier than just back and forth in my opinion.
   / How are you guys lifting a mid mount mower upright for winter storage #13
To store my wife's mid mount mower from her BX 2670 I drilled a hole in the steel beam of my shop then put a celvis there. I used a safety chain from a boat trailer to hold it. This is also make it easy to remove the blades for sharpening.
   / How are you guys lifting a mid mount mower upright for winter storage #14
I lift or move my MMM with the FEL. For service, I lay it upside down on sawhorses outside to scrape the grass pack, the blades and hardware there, or even paint it. While it is upside down, the gear oil is drained into a bucket, to be refilled later in the project. On sawhorses , outside, the working height is convenient, the dirt or overspray is no problem in my gravel work area. The guide wheels, blade hardware and driveshaft are cleaned later and stored in the basement. Lastly, after a greasing, the MMM is stored outside over the old sandbox on slats/ a skid, then covered with a good tarp. Having two sets of blade hardware and blades ( to be sharpened/cleaned later), it is ready to go in the spring by using the FEL (with chains on the bucket hooks) to move it for mounting again.
Cheers,
Mike
   / How are you guys lifting a mid mount mower upright for winter storage #15
With casters that swivel a full 360ー I can move it very easily, in any direction, one end or both ends. Much handier than just back and forth in my opinion.
Picture works everywhere else.....
   / How are you guys lifting a mid mount mower upright for winter storage #16
I use a set of home made axle shafts and set of old lawn mower wheels to store my deck upright...
They aren't very pretty, fit kinda loose, but work just fine... And were cheap to put together....
Besides... It makes it a lot easier to clean out the under side after you set it up with the loader....
Good luck...
Problem solved. Bought a pair of pallet forks that attach to loader bucket. Secured lift arms and pto shaft on mower then attached tow strap. Lifted mower upright with forks and attached axles like Wyobuckaroo mentioned. I used 10" pneumatic tires purchased at Harbor Freight for $6 and seems to work pretty well. Thanks for the help guys.
   / How are you guys lifting a mid mount mower upright for winter storage #18
View attachment 399077View attachment 399077
Nice job. Did you paint those wheels? I don't recall HF selling chrome ones....
Those are actually zinc plated hubs. They have wheels with black, white, and zinc hubs. Got the zinc because I thought they looked sexier. Kind of like the old saying that wheels make the car <g>.
The mower axles were built starting with a 2' section of 5/8 all thread rod. Then covered that with 1/2" conduit. Put 3/4" conduit over the 1/2" and then put 1" conduit over the 3/4". Drilled hole through all 3 conduits down to the all thread rod and used tap and die set to insert set screw to hold everything together. Secured tires with washers and bolts. This is going to be useful for saving space, cleaning deck, and sharpening blades. This forum is great. Always get the answers I'm looking for. Thanks to all for being so helpful.
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
