Snow Equipment Buying/Pricing How are these things in the snow anyway?
   / How are these things in the snow anyway? #1
Woodworkerman
Dallas, PA
Kioti DK45S Cab
I am trying to find my first tractor and one of the top reasons for the purchase is the removal of snow from a long, steep, paved driveway. I would like to be able to use a 2 stage snow-thrower implement to do the task, but I find myself wondering how a heavy tractor will react on a flat snow/ice covered hill in the winter. Anyone have any experience with this? If so, any recommendations or cautions? Thanks.
   / How are these things in the snow anyway? #2
If your not using snow chains, it'll act just like this,,,, minus the steering option.
   / How are these things in the snow anyway? #3
Workerman- I just got my M-F GC2310 last February, with a 50" 2-stage front mount snowblower... I got chains with it, but found that I didn't need them on my sloped, hard-pack driveway, even with icy conditions-- this with turf tires!
I actually disengaged the 4-wheel drive after several snowstorms, and still did OK- a fair amount of sideways creeping --following crown of driveway-- going uphill (wieght shift due to slope, I believe), but it was fine going downhill- no sliding or tire spinning. Needless to say, I was impressed. BTW, the blower worked great, throwing even wet, icy/crusted snow a minimum of 45'.
Sorry, I was too busy blowing snow (and nobody else wanted to get up!) to get any pics of the blower in action. The sloped part of my driveway is about 150' long, with a wide area I keep cleared at the bottom in front of the garage.
  • upper drive:curve.JPG
  • lower drive:garage.JPG
   / How are these things in the snow anyway? #4
I'm on my second tractor with turf tires and a front snowblower. I've never had any problems getting around, and we were bombed with snow last year. I will say that the tractor didn't go so well when i was on my lawn (don't ask), but on pavement or dirt it was a non issue. I has times i went quite a ways before i even realized i was only in two wheel drive.
   / How are these things in the snow anyway? #5
I really think it depends on what you mean buy ok? I have ag tires and can go through twice as much snow as my neighbor with turfs and his tractor is 10 hp bigger. My good friend has the same tractor as I do minus the FEL and he has R4's and complains it will not steer in the snow while using a rear grader blade when there is more than 4-6 inches of snow. I can handle 1.5' no problem due to the R1 ags and the extra weight of the FEL on the front tires. I would stop and ask a few of you neighbors what they are using.
Chris
   / How are these things in the snow anyway? #6
I currently have a moderately steep 900' drive that is road-base material. I have an estimate to pave it along with a drainage curb, and plan to use my future tractor to keep it snow-free. The snow here is mostly powder, so I intend to use a rotary-broom (using front hydraulics) to sweep it off. If it is wet-snow, I'll use the FEL to push it all downhill and off to the side. We get so much sun here that it melts pretty quickly. Just have to stay on top of it.
   / How are these things in the snow anyway? #7
My tractor was delivered with the V chains on it already... cleared snow on 1/3 mile dirt road and 2 dirt driveways with my rear blade and FEL... it was like driving on dry pavement. I did have one of the loose chain ends catch on the brace for my 3pt hitch... bending it and causing a few cursed words to be uttered and the consideration of not putting the chains on next winter. Also the driveway will be paved by then.... I hope... and I am not sure how well the chains and asphalt are going to get along.
   / How are these things in the snow anyway? #8
I have a couple of very steep driveways,one paved and one hardpack. I normaly plow them with a pickup ( a lot faster) but have ,after a very heavy snow used the Kubota and 63" rear blower. I haven't chained up but with the Ag tires only need to give a 'push' with the front bucket on the steepest part of the hill when it is icy. I have also driven up and blown down ,R1's are directional and pull a lot better forward. Do be careful about spinning with chains on blacktop, that's gunna leave a mark !
   / How are these things in the snow anyway? #9
You could put some metal screws into the lugs.
Do a search. You'll find these are what they use to race motorcycles on iced over lakes.
I put them into the outer parts of the lugs on my Gravely Ag tires. Didn't really get a chance to try them out, as I acquired my 4wd JD a year or so later. Haven't put the screws into its turf tire lugs on the JD, as my driveway if rather flat, and the JD has very good traction in the snow without the screws.
Ralph
   / How are these things in the snow anyway? #10
I'm on my second tractor with turfs and a 3 pt snowblower. No problems with traction. I usually run in 2 wheel drive so that if I contact something in the snow with the blower the wheels will slip before I tear something off the blower.
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
Heavy Haul trailer (A49461)
Heavy Haul trailer...
Westendorf Gravity Wagon (A50514)
Westendorf Gravity...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2018 KENWORTH T680...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
