How are the hydro drive tractors doing in the bitter cold ?
   / How are the hydro drive tractors doing in the bitter cold ? #1
slowrev
Elite Member
Goffs Corner, KY
IH 2444
Just curious.
   / How are the hydro drive tractors doing in the bitter cold ? #2
I plowed 6" of snow off the driveway the other evening. Temps were right around 0. No problems. Never had problems any other year either.
I believe that you need to let the tractor warm up a bit when the temps drop down low, but that is just as much for the hydraulic fluids so they flow as for anything else. In low temps I find the hydraulics can be sluggish.
   / How are the hydro drive tractors doing in the bitter cold ? #3
I had no problems at all last winter. My biggest problem this year is lack of snow :mad:! I did have my diesel fuel gell up one time this year when the temperature was around zero, but I have had no problems with the HST and/or hydraulics other than a little initial "whining" while the tractor was warming up in single digit temperatures. Tractor ran fine after warmup :D. Who would not whine when waking up to zero temperatures :eek:? Jay
   / How are the hydro drive tractors doing in the bitter cold ? #4
Mine has been just fine. As with the others, I warm it up, 5 minutes or so. I use light pedal pressure until warmed up well.
   / How are the hydro drive tractors doing in the bitter cold ? #5
According to the news, your prayers may be getting answered. Is 8 feet of snow a lot of snow? I hear that is what New York may get.
   / How are the hydro drive tractors doing in the bitter cold ? #6
I had trouble in years past due to the HST filter blowing out from high pressure from the pre-charge pump. Kubota's 3rd generation filter has been perfect (knock on wood) so far. First 5-15 minutes of warm up with the clutch dogged down. Pre-charge pump works unless the clutch is down.
jb
   / How are the hydro drive tractors doing in the bitter cold ? #7
jb
John, are you using SUDT or equivlent?
   / How are the hydro drive tractors doing in the bitter cold ? #8
Mine does just fine in cold weather. :D
Needs to be plugged in to start though!:(
Operator is the worst problem. He has to be Kick started!:D
At -35C the operator is only good for a few hours before his hydraulic and fuel lines gel up. An addition of some warming additive does wonders. :D Then he's ready for another few hours.:D :D
   / How are the hydro drive tractors doing in the bitter cold ? #9
No trouble with HST but like others say hydraulics can be a little sluggish til the machine has warmed up good. SUDT isn't available from Kubota dealers in my area of Ontario. I use CASE HYTRAN. Many Kubota dealer sell CASE equipment and say the Hytran is a superior oil for our cold climate.
   / How are the hydro drive tractors doing in the bitter cold ? #10
Fine,after fluids are warm.
2018 FORD F-150 (A53843)
2018 FORD F-150...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A53473)
DeeZee Crossover...
2023 BOBCAT T770 SKID STEER (A52706)
2023 BOBCAT T770...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A54607)
2007 PETERBILT 379...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
