How are my turf tires going to handle this job?
   / How are my turf tires going to handle this job? #11
Took this pick a few wks. ago fairly steep climb with loaded turf tires but no counter weight. When it's wet gumbo clay you keep the tractor in the garage.
Give it a try. If it does not work you can add chains or go to a different type tire or add more weight to your tractor. About 99% of the time you will have more power than traction.
BTW - Welcome to TBN Jerry.
Thanks for the welcome. Actually I'm a returning member, and have enjoyed this site for years.
I agree with your comment, and chains are an option I'm considering anyway for year round use. Thanks again.
   / How are my turf tires going to handle this job? #13
Your tires will be fine . You will have to learn the box blade !
   / How are my turf tires going to handle this job? #14
I cleared residential snow over 5 winters just outside of Winnipeg Manitoba with Kubota tractors.
Started with a BX24 and graduated to a B3030HSDC.
I had great success with the loaded turf tires on the BX24, and when I got the B3030, the weight of the FEL and rear snow blower were more than sufficient to get the job done...even on glazed and wind packed snow.
   / How are my turf tires going to handle this job? #15
R3 Turf tires are actually preferable unless you're in deep mud like in the photo above.
More biting edges, more surface contact, more pliable sidewalls, it all adds up to more traction.
R4s are terrible, and R1s are only good if you're in that mud that was pictured in the post above me.
   / How are my turf tires going to handle this job? #16
Stay outta the mud with turf tires and if you feel sporty, be sure you have a snatch strap for your pickup truck.
   / How are my turf tires going to handle this job? #17
As soon as that started, I’d go back to the house and wait for dry weather. It’s taken me too long to get grass and gravel holding everywhere to tear it up like that.
   / How are my turf tires going to handle this job? #18
I can't imagine plowing snow with turf tires, or indeed going into my woods, which tend to be on the wet side.
   / How are my turf tires going to handle this job? #19
Bill that was only a short stretch of a mile or so of trail that was dry.
I have a long steep driveway as long as it's cold I can plow going up as well a down with no chains. Unfortunately there's always wet snow falls and times when it's glare ice so I use rear chains with cross links every second link. This was before I had the chains made and the conditions were good.
   / How are my turf tires going to handle this job? #20
I have an interesting 'back to back' experience to share.. I have a B6100 tractor with 29x12.5-15 turf/r3 rear tires, and a b7100 which i bought to resell, with 8-16 R1 bar/ag rear tires. The tractors are pretty close to identical despite the model difference, BUT the 6100 has an FEL while the 7100 has 3 x 55lb front suitcase weights.
I also have 2 60" box blades (one came with the 6100, one came with the 7100). The 6100 with turf tires pulls the 60" box blade better than the 7100 on dry ground.. but that's not all. The box blade on the 6100 I added 115lbs to, which is almost a 30% weight gain on the implement.
So the 6100 with turf tires pulls a heavier box blade, better than the same tractor with r1 tires. I attribute some of it to the weight difference between the front end loader and the suitcase weights which is probably about 200lbs, but.. the main point is that turf tires are NO handicap on dry ground.
2005 Nissan Pathfinder SUV (A53424)
2005 Nissan...
2015 Ford F-250 Auto Crane EHC32 3,200lb. 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A57024)
Gleaner N630 Corn...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2017 JCB 510.56 10,000lb 4x4 Rough Terrain Telehandler (A55851)
2017 JCB 510.56...
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
