Youare
Platinum Member
I have a 1951 Ford 8N and a 2001 Kubota L3000DT.  The Kubota is rated a couple of horsepower more on both the engine and PTO.
I have a Farmi winch that I have used on both tractors. Two things are really noticable. PTO horsepower is developed at very different engine RPM's on each tractor. The 8N is a slower turning engine, the Kubota dosen't reach full PTO speed until you get to 2300 RPM.
I have found when using the winch pulling logs with the 8N it will out pull the Kubota even though it is rated a little higher in horsepower. The other big factor is tractor weight, the 8N is a little heavier than the Kubota.
The horsepower to weight ratio on the 8N is better than that of the Kubota. One is a utility tractor the other is a compact.
Power steering, 4WD, better loader, and more speed ranges make the Kubota shine. However, the 8N was one nice tractor.
Randy
Randy
