How agriculture works thread
   / How agriculture works thread #351
The glass 'splices' (upper and lower side panes have a rubber H shaped strip installed between them, I believe to mitigate and potential failure from any flex in the cab structure. If the glued in glass contacts another pane, one will fail. One issue with glued in versus rubber floating is fitment. The pane has to fit correctly in the channel or it's failure time as well. The pane cannot contact the metal frame anywhere, which is why you never want to buy aftermarket, always OEM at the high dollar price. Kind of reminds me of the newer radiators with their plastic upper and lower tanks 'Sonically' welded to the cores. Gone are the days of getting a radiator recored as most radiator shops cannot reinstall the expansion tanks, don't have the proper equipment to do it. Sometimes improving a component means replacement of a like component instead of rebuilding it.
   / How agriculture works thread #352
Great video!!!! I'm always amazed how much things are different in different areas. I've never saw a plow like that. I shared it with my large farmer friends here in Missouri. Mile long rows, WTH!!!! :)
Things are big here, like this ranch that is bigger than Rhode Island.
   / How agriculture works thread #353
I wonder, what would be the average Soy Bean yield in the field that he's plowing? How about corn yield?
   / How agriculture works thread #354
They make trucks too.
   / How agriculture works thread #355
How about cotton, since it was a cotton field.
   / How agriculture works thread #356
I was told by a farmer in Lubbock that he averages 2.5 to 3 bales of cotton to the acre. Looking over their fields a couple years ago it look like they would be lucky to get a bale to the acre. But I never raised stripper cotton like they do. We always had tall cotton.
Some of the farmers out there do sunflowers. That is something I never did either but it sure is pretty looking over the huge fields of sunflowers.
   / How agriculture works thread #357
I looked at some of his other videos where they were stripping cotton. He wasn't doing well in some fields; they looked skraggly and he said not enough water. The better field the yield was mid 3/acre and went up to almost 5 at times.
   / How agriculture works thread #358
Several years ago we had a very bad snow storm. Country folks were stranded. I spent days/nights in the grader. Catching naps in the cab. I was not very happy.....
When you say "grader" are you talking about one of these?
Once the town used it on the 4 lane highway when the ice built up to 2+" (back in 96-97) but that's the only time I've seen it for snow use.
   / How agriculture works thread #359
Whooppss, got me, I thought it was bean stubble. Okay, tell us cotton yield. Thanks for the correction!!! :)
   / How agriculture works thread #360
I naively ask for clarification? Not knowing anything about cotton. What would be the highest yield? What would be the lowest? Thanks!!!!
UNUSED GRASSROOTS IMPLEMENT 6' BOX BLADE (A57192)
UNUSED GRASSROOTS...
Pig Statue (A55853)
Pig Statue (A55853)
2017 Jeep Patriot 4x4 SUV (A55853)
2017 Jeep Patriot...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A57193)
UNUSED RAYTREE...
JOHN DEERE 3020 TRACTOR (A54756)
JOHN DEERE 3020...
