Buying Advice hours of operation?
   / hours of operation? #11
With the TC45D, there are several things to check as listed below. I'll try to keep them in some order so you can work your way from the front of the tractor to the rear.
1. Battery area - this is a bad area on most TC45Ds of this age. The battery stand, radiator, and HST cooler lines behind the battery may be severly corroded. Lots of posts here about that problem.
2. Check over the front differential well and check the dipstick on the left side 4wd axle housing (yellow plastic screw cap). Look for evidence of good greasing on the front axle pivots grease zerks (one in front of axle and one behind).
3. Check the condition of the fan belt. It may be worn/cracked badly on a 3000 hour tractor. Check the condition and level of the radiator coolant.
4. While the hood is raised, look for any obvious hydraulic leaks around the steering column and power steering reservoir. Pull the cover on the air breather on the right side of the engine and check that it has been serviced properly. There is an outer (large) filter and an inner filter that is supposed to be changed every 1000 hours of operation.
6. Check the engine oil level and that there are no leaks.
7. Close the hood and make sure the hood latch locks and releases properly.
8. Go to the operator platform and check the operation of the tilt steering. The steering wheel should move when the lock lever is raised and lock into place when it is released. If this is not the case, the hydraulic actuator needs replacement. The steering wheel is also supposed to extend and retract as a function of the big knob in the middle of the wheel. It may not do that since it is common to not be operational.
9. Now, while sitting in the seat, turn the key ON (don't start) and look at the instrument panel. You should see the alternator and oil pressure warning lights. The fuel gage should also work. Start the engine and look for the tachometer to indicate as it should and the oil pressure may go out, come on, and go out again. This is pretty common. Unfortunately, we don't have an actual oil pressure gage, only an idiot light. The temperature gage should also operate, but it will take awhile to come up to operating temperature. Don't let anyone smooth talk you about the instrument panel. The fuel, temp, and tach are all individually replaceable. You don't have to replace the whole panel if one of them doesn't work. If there is nothing attached to the PTO, go ahead and engage the PTO with the lever on the left side. See that the PTO indicator light comes on on the instrument panel and goes off when you move the lever to disengage. Probably, if the backhoe has been on the tractor most of its life, the PTO has been used very little. That's a good thing because PTOs are easily damaged on these tractors if they are abused.
10. After the tractor is running, check out the loader operation. You can expect the loader to be a bit loose if it has been used often. My loader gets hard use and it's a bit loose despite my doing regular greasing. While you have the joystick in your hand, press on the rabbit/turtle switches and watch for the light on the fender switch (orange switch) to change with the joystick switches. When you actually drive the tractor, do this again to see that the transmission changes speed as it should with the rabbit/turtle switches.
11. Unfortunately, with the backhoe, you won't be able to check the 3PH or hook anything to the PTO, so you will be really limited. While the tractor is running, check the backhoe for operation and look for unacceptable leaks or improper operation.
12. Finish your checks by driving the tractor and making sure things like brakes work properly and the tractor drives without any strange noises. Check both Hi and Lo ranges of the transmission with the lever on the left side fender panel. There are two ranges and two speeds (rabbit/turtle) in each range so that you essentially have a 4-speed HST on this tractor. There is no clutch, so you don't have to worry about that.
13. After the tractor is warmed up and operationally tested, shut it off and crawl under it to look for leaks or drips.
Whew! I'm getting tired of typing, and those are the big things I can think of right now. Some things you just won't be able to check with the backhoe attached, so you might try and negotiate for those items to be guaranteed by the dealer. Otherwise, maybe you need to ask him to remove the backhoe and let you test the 3PH and PTO. I think I'd want to do that on a 3000 hr tractor.
You haven't mentioned price, so I won't say much except I'd expect this tractor to be over $12k if everything works, but no more than $14k. If it's rough, I'd be offering less. The tractor with backhoe probably sold new for around $27.5k. With these hours, I'd say it is not over 1/2 the original cost and maybe even less.
wow Jim,
with this on paper, the dealer will have his salesmanship cut out for himself. You made my job much easier. Going this week to look at the NH and then an orange (so called) L35, 1400hrs, $18k. The NH was ball parked at 15k (they have not looked at the machine yet). The NH is a TC40D, how much price difference then?
Paul
   / hours of operation? #13
=The NH is a TC40D, how much price difference then?
Paul
On that tractor with those hours, there's not much difference. If you were buying a new tractor, you'd expect a difference, but no more than a couple hundred dollars at best on this deal. Now, if it were a TC35D of the same age and hours, it would be significantly less because the TC35D has a 3 cyl engine instead of the TC40/45 4-cyl engine.
   / hours of operation? #14
Jim, could not expect any less from a learned person like you. Great post. I might come back to this post for future reading pleasure.:thumbsup::thumbsup:
JC:)
Hey guys,
I looked at a 2001 Kubota L35 and all looked and ran, I guess OK. I was told that the tcd40 was an agriculture grade vs commercial grade and the frame was not as strong. Is this really an issue or sales jargon? Should be looking at the NH tomorrow.
   / hours of operation? #16
Raider43 said:
Hey guys,
Jargon. The only exception is if we are talking about a true TLB.
   / hours of operation? #17
Hey guys,
I don't know for sure, but the dealer's comment is probably relative to the NH TC40D's being a loader/backhoe. What the dealer says is true. The TC40D is not nearly the same frame strength as a commercial TLB like the big yellow ones you see on construction sites. It's an ag tractor with a backhoe installed. It was not built as a dedicated TLB.
New Holland has it's own commercial lines of large backhoes weighing around 20k lb and having a hp range of 95-110 hp. Kubota has the L-series TLBs that are really nothing but ag tractors set up as dedicated TLBs with maybe a few extras. These are for people who need a backhoe exclusively and will probably not need a 3PH in the rear. These tractors have a single flip-over seat instead of two separate seats: one on the tractor and one on the backhoe frame like the backhoe on the TC40D. The Kubota backhoes generally have very good specs.
So, while a Kubota dealer may extol the virtues of their TLBs. They are not as flexible as the tractors sold primarily as AG tractors with a backhoe added (my opinion). Once you remove the TC40D's backhoe, you can put any implement on the 3PH and use the tractor for many utility tasks. It's much harder to do that with Kubota's line of small TLBs. Kubota TLBs are also more expensive than the New Holland.
thanks Jim,
that is the next conversation to have with the salesman, "how do other pieces of equipment interchange".
I'll be back.
Paul
Hello Jim and others. Thanks for your help. I am leaning towards the "2001" L35, as it appears to be much more machine for the dollars that I am being quoted. The TC40 they want 15k and the L35 16.5k. Checking out the L35 tomorrow for the second time. I may start chatting on the Kubota forum.
thanks,
Paul
   / hours of operation? #20
They are both probably good tractors. Just be thorough in your examination and go with your gut feeling. It sounds like you are on the right track to me.
2371 (A58376)
2371 (A58376)
2014 WESTERN STAR 4900 SB ROAD TRACTOR (A51406)
2014 WESTERN STAR...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
2013 Express 20' Cargo Trailer (A57148)
2013 Express 20'...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
