hours meter
/ hours meter #1
KubotainNH
New Hampshire, USA
Kubota B6100
Hello, I can't seem to stay off this site. I have a question about the hour meter on my B6100. What is the far right digit on it? Is that when the hours roll past 9999 or something else? It looks like a fat 1 or I and the left side says 1100.5. I'm just wondering if it 1100 hours or 11100 hours which seems to be way to much. The tractor runs like a top and is in very good shape for it's age. Thanks.
/ hours meter #2
It's 1/10 of an hour, much like the 1/10 of a mile on your odometer.
/ hours meter #3
</font><font color="blue" class="small">( It's 1/10 of an hour, much like the 1/10 of a mile on your odometer. )</font>
Yup, if you watch it will change once every 6 minutes.
Bill Tolle
/ hours meter #4
Actually, I looked more closely at the meter. There is one further slot to the right, AFTER the 1/10 position. It alternates between a I and blank indication. It seems to change about every 3 seconds, so I guess it's kinda like a 'working' indicator to let you know your hour meter is ticking away.
/ hours meter
Aha, that's the one I was talking about. I need to do some yard work tomorrow with the tractor and will watch it for a bit. Thanks.
/ hours meter #6
</font><font color="blue" class="small">( Yup, if you watch it will change once every 6 minutes.)</font>
That's what I initially thought as well until I noticed the clock ticked faster as the rpm's increased. So I timed a tick at 1000 rpm. It took about 16 minutes. Increased the rpm's to 2000 and it took just 8 minutes. Talked to the service manager and he said the behavior is normal.
So the hours are really closer to full throttle or PTO hours rather than actual timed runs.
/ hours meter #7
That now makes sense. When I first started using my BX for mowing, I noticed the hour meter seemed to go by faster than I expected, as mowing is at full throttle. These last week, as I was using the loader to move soil and gravel at half throttle, it seem to go much slower.
So it seems the hour meter is somewhat tied to the RPM? Hmm, if that is the case, maybe I could use that hookup to jury-rig a tachometer. Tiny-tach is out of diesel tachs and I've been waiting for weeks!
/ hours meter
I wonder if it's more a voltage thing with the powerfull dynamo's we all have. Maybe works like a clock with a low battery.
/ hours meter #9
many companies have begun to have the hour meters run a little slower when tractor is not running at "normal" specs. IE when idling computer slows hour meter as maintenance is determined by use (hours) since it is idling it thinks it is not working so it slow hour meter so you do not "over maintain" unit. Hour meter will run at "normal time " when engine RPM is at recommended RPM of engine; say 2600 RPM. All that said it is a way to save the operator some money on maintenance. Also I do not know it Kubota is using these hour meters but it sounds like they are.
/ hours meter #10
Well, so much for the rpm theory. Received my shop manual today, and the hour meter is simply connected to the power on circuit of the key switch! So it must be purely time based.
The hour meter on the BX looks identical to the Hobbs 85010 model, so Kubota probably OEMs it from them, and that is purely time based too.
/ hours meter
Hmm, I watched it today and the rightmost digit did not move. The 10ths one did. I attached a picture of it.
/ hours meter #12
</font><font color="blue" class="small">( That now makes sense. When I first started using my BX for mowing, I noticed the hour meter seemed to go by faster than I expected, as <font color="red"> mowing is at full </font> . These last week, as I was using the loader to move soil and gravel at half throttle, it seem to go much slower.
)</font>
<font color="red"> I never mow at full throttle . </font>
1/2 to 3/4 th . mows easy with power to spare.
/ hours meter #13
</font><font color="blue" class="small">( Hmm, I watched it today and the rightmost digit did not move. The 10ths one did. I attached a picture of it. )</font>
<font color="red"> How long did you watch it ? </font>
<font color="brown"> How much did it move? </font>
/ hours meter #14
<font color="blue"> the hour meter is simply connected to the power on circuit of the key switch! </font>
<font color="green"> Connect it to the key on position of the switch and drastically reduce your hours. </font>
/ hours meter
I used it for an hour or 2 and never noticed it move. Maybe that digit is broken.... or I was having to much fun using the tractor. /forums/images/graemlins/grin.gif
JOHN DEERE LV4115 TRACTOR (A63276)
JOHN DEERE LV4115...
2022 EZ-GO ELITE...
Jack Daniels Metal Decorative Sign (A64557)
Jack Daniels Metal...
UNUSED 2023 JCB S3246E ELECTIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
2022 Honda Ridgeline AWD Crew Cab Pickup Truck (A64556)
2022 Honda...
