hours clock
   / hours clock #1
flyboyjohn
83 Yanmar 3110
My hours clock just died on my yanmar 3100D tractor. it only said 11.8 hours on it because I was told it was replaced only a month ago. I was also told these things quit working quite often, is this true ???:(
   / hours clock #2
Yup, they also speed up and slow down with engine speed. It's more of a rough estimate guage than an actual hour guage.
   / hours clock #3
Did the tachometer stop working too?
If so, the cable is broken...
Or it could be just a broken odometer.
   / hours clock
Yeah, everything quit working. The rpm needle and the odometer just stopped.
and then yesterday when I started the tractor, the rpm needle worked for about ten seconds and then back to zero. it sounds like a loose or broken cable doesn't it...I 'll find out shortly
john
   / hours clock #5
You can buy a new one at Yanmar Tractor Parts - Shop Online
When you replace the old cable, tape the new one to the end of the old cable with duct tape on the dashboard end of the cable.
Then pull it thru the dashboard and into the engine compartment.
Pulling it is a lot easier than pushing the new one through the mess of wires, fuel tank ect....:D
   / hours clock
thanks a lot
John
   / hours clock #7
mine stopped working. Found broken cable. Replaced cable. Cable broke again. The gears would bind in the tach / hour meter & break the cable. Dealer replaced tach/ hour meter durning warranty
   / hours clock
Kenmac, thanks a lot, already ordered the replacemen cable and also got a lot of great advice from all the folks at this website
thank you all
John
2013 Club Car Carryall 252 Electric Utility Cart (A51691)
2013 Club Car...
2015 Kaeser M114 100psi Towable Air Compressor (A51691)
2015 Kaeser M114...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
John Deere 853 20ft Corn Head (A53473)
John Deere 853...
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F750 XLT...
