hour meter
/ hour meter #1
rexman
gray,maine
2003 toro 419xt
my hour meter stopped working this weekend.i checked the fuss and the fuss is working.is this a commen problem or is there something else i shouldcheck.thanks
/ hour meter #2
rexman,
I had a 1998 Toro Wheelhorse 3148 garden tractor. The hour meter stopped working at around 450 hours. I checked everything possible that would be associated with the hour meter not working. I couldn't find the problem. I had my dealer look at it and they couldn't find a problem either. So, it was time to buy a new hour meter. $40.00.
arthurb,
/ hour meter
i have a 2003 toro wheelhorse and i checked out everything also and its still under warrenty so i will have to get me a new one.ty for the info.
/ hour meter #4
And, speaking of hour meters, to much my displeasure I discovered that the one on my Sears DGT6000 counts time by the ignition switch being on and not by the engine running.
Seems my youngest son was playing with daddy's little toy and he turned the ignition switch on and left it that way for an additional 88 hours. So, now it is showing more hours than it actually has. Thank goodness (knock on wood) that it has been trouble free for the past 2 years. /forums/images/graemlins/smile.gif
/ hour meter #5
Unhook the hour meter and keep track of it with a watch and pad and pencil for 88 hours then hook it up again. I don't think you can get them to run backwards.
Dickson Ind. 4080 SX Turbo Blast Asphalt Surface Prep Machine (A64194)
Dickson Ind. 4080...
Stout Utility Grapple XHD76 (A66285)
Stout Utility...
3-Pt Hydraulic Tree Spade (A66285)
3-Pt Hydraulic...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A64553)
2025 GIYI GY-PG72C...
Tri Axle Rolloff Truck (A64194)
Tri Axle Rolloff...
2022 EZ-GO ELITE...
