hour meter
   / hour meter #1
ron45
N.M.
Kioti LK3054XS
Is It difficult to turn back the hours on a Kioti meter? I some times wonder if I got hood winked on how many hours were on the Kitoi I bought.
Ron
   / hour meter #2
Yes, very easy with a device hooked up to the tractor.
   / hour meter
No one is answering this question. Are you afraid I'm a tractor terrorist. I don't care how it's done I want to know if I've been had?? So call of the choppers and help me out please.
Ron
   / hour meter #4
Ron
RON,
It depends on whether the meter is mechanical or electric. If it is mechanical, with a cable similar to a speedometer cable attached to it, YES it can be turned back. If it is electronic (digital) then it can NOT be turned back. If it is electric (hooked up by wire with rotating numbers like an old style odometer) it can be turned back, but it has to be disassembled to do it. Please post picture of face of meter and maybe I can give you a better answer. :D:2cents:
Dave
   / hour meter #5
It's a cable operated, mechanical meter
   / hour meter #6
Ron
Also - define "hours on Kitoi (sp)"
My B7610 runs the meter based on PTO speed. I have spent many hours running back and forth with stuff at around 1200 rpm to get it to register 1 hour.
Some tractors base on total elapsed time the tractor is powered.
   / hour meter #7
Is your M4700 the same as the B7610 as I have thought my M5700 was based on eng. speed as well ?
   / hour meter #8
It depends on the model.
My older model DK 35 uses a cable and the meter is based on PTO speed to register 1 hour.
The newer style DK's are electrical meters and are based on engine run time.
If the 3054 meter is cable operated it is likely based on PTO speed.
PT 500 Gal Water Tank (A50121)
PT 500 Gal Water...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
2016 GMC Sierra Pickup Truck, VIN # 1GTN1LEC5GZ901362 (A51572)
2016 GMC Sierra...
2017 JLG 1932R 19ft Electric Scissor Lift (A50322)
2017 JLG 1932R...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2005 Mack Vision Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Mack Vision...
