Hour meter repair?
   / Hour meter repair? #12
I had the same problem with my 1715 and after my research it was cheaper to just replace with new. The plastic gears that drive the hour meter wear out and most shops won't replace them or parts were not available. I checked my old receipt and I replaced mine 13 years ago and the cost was $130 from the dealer.
   / Hour meter repair? #13
   / Hour meter repair? #14
I think that OEM mechanical hr meter is calibrated to register 1 hr @ rated 450 PTO rpm. I hardly ever run my rig at 450 pto rpm or 2400 engine rpm unless I need it, so it will take me more seat time than one hr for the hr meter to reflect 1 hr. While in college I had an issue with my speedometer so I bought a cheap tach, calibrated speed based on RPM and used it for many years. Of course , I had an ignition system with gasser to get a signal for the Tach. We all know that diesel does not have electrical ignition.
Brush cutter (A55973)
2018 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2018 ALLMAND BROS...
Case Backhoe (A55973)
2017 John Deere 1025R Tractor - 626 Engine Hours (A55315)
2017 John Deere...
2011 Atlas Copco XAS 375JD6 Towable Air Compressor (A55973)
2011 Atlas Copco...
2020 John Deere 1025R MFWD Compact Tractor (A56435)
2020 John Deere...
