Hour check 2210
/ Hour check 2210 #1
Hambone
Platinum Member
Southeast Kentucky
JD3032
How many hours does everyone have now? Just curious how they are holding up. I turned 248 last night.
/ Hour check 2210 #4
Hambone
241 hours on the clock.
Malvern /forums/images/graemlins/grin.gif
/ Hour check 2210 #5
12 hrs and still smells new.
/ Hour check 2210 #6
54 hours and just did the 50hr service. /forums/images/graemlins/grin.gif
/ Hour check 2210 #7
<font color="green">237 hours for me!
Moved about 10 ton of crushed stone with it this past weekend using the FEL.
Sure beats using a shovel and wheelbarrow. Been that route before. Never again. Getting too old - me, not the tractor.
Mike</font>
/ Hour check 2210 #8
115 fun filled hours /forums/images/graemlins/grin.gif
/ Hour check 2210 #9
Only 41 here so far...zero problems. Got an 18-Wheeler full of gravel and entertained myself this weekend. Pesky stuff wouldn't level too good back-dragging with the FEL, so naturally I had to run down to Big-R and buy a 5' rear blade. /forums/images/graemlins/wink.gif. Running out of places to put implements...Oh, the humanity.
/ Hour check 2210 #10
124 hours. Back to dealer for toplink oil leak and different-sized rear tires within first year. Not using it much this summer, very dry = minimal lawn mowing. I like it more now that I've added the X series seat/suspension and the femco folding ROPS - handy when mowing under trees. I love my tractor!
/ Hour check 2210 #13
376 hours on my 2210 as of today, Sept. 8, 2005. Still running very nicely.
/ Hour check 2210 #14
JDLou,
How did you ever make out with that PTO shaft issue? 376 hours -- you sure have been giving that 2210 a workout! /forums/images/graemlins/tongue.gif
/ Hour check 2210 #15
Folding ROPS.....ordered direct from Femco, $299 plus shipping IIRC. Fit and finish match OEM and everything lined up the first time.
/ Hour check 2210 #16
JDFanatic:
Thank you for your inquiry on the PTO shaft and sorry for not posting the outcome, I got a little bogged down in work-related matters. I am impressed by your ability to keep up with so many posts and your always-valuble feedback and suggestions. In any event, the service dept. at my dealer advised that an "off-axis" measurement at the end of the shaft of under 50/1000ths is "within tolerance" and not a cause for concern. I figured mine to be around 40/1000ths give or take. Also, ran the rear PTO shaft with no load for multiple tests and never detected an inordinate amount of heat due to bearing damage or displacement. In the end, while it looks a little freaky, I apparently freaked out more than necessary. One reason that I thought it was worse than it is at first was because, when I took my initiatial "off-axis" measurements, I neglected to divide by 2, which my method required. I eventually figured that one out on my own and was greatly relieved that the off-axis was not the roughly 80/1000ths I initially thought it was. I will always keep periodic tabs on this, but it does not seem to be an issue at present. I am a little bit of a perfectionist and maintenance freak though, and something like this could really drive me nuts if I let it.
Best regards,
Lou
/ Hour check 2210 #17
FredG, Would it be possible for you to post a pic with the ROPS folded down? I went on the Femco website and all I can see are pics with the ROPS up.
JDLou, Glad to hear the PTO shaft angling was within the manufacturing tolerances, but I hear you -- details like that bother me too! /forums/images/graemlins/smirk.gif
/ Hour check 2210 #18
192 hours thus far, but I fear that will jump by 30 or so over the next few weeks. Starting to install our yard this fall, 3.5 acres to seed. I was hoping to disc it all up, but this hard Indiana clay just won't have it. So the 450 tiller is being put to the task. Unbelievable what this tiller can do, but I hate all those burried rocks.
I did have the 2210 in earlier this summer for soft hydraulics on the FEL. It would come an go, allowing the bucket to move without input from the stick. Both curl and lift. The replaced the valve under warrenty and it seems better, but still not tight like my old 445 with it's 40 loader.
John
/ Hour check 2210 #20
Just turned past 120 hours. Just got my machine back from the dealer--who was replacing a leaking seal around the mid-pto-1 month shy of the 2 year anniversary!
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
Butler MFG Water Tanker (A63688)
Butler MFG Water...
Ledwell Hydratail 48Ft Trailer (A64194)
Ledwell Hydratail...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
Boomless Sprayer (A64127)
Boomless Sprayer...
2007 50FT T/A 3 CAR HAULER TRAILER (A59914)
2007 50FT T/A 3...
