Hot Tub Experiences?
/ Hot Tub Experiences? #1
daugen
Epic Contributor
New Hope PA
in between now
And I don't mean what you did in them...:dance1:
but rather have you owned one, and did you learn some
"boy I wish I knew this before I bought this thing" important knowledge?
I'm considering a small three person hot tub for my back porch so I can soak in hot water for
what is unfortunately pretty serious arthritis. Luckily hot water helps immensely.
The ones I have looked at are pretty fully equipped, though I do not want light or music packages.
I want peace and quiet back there, not winky lights and subwoofers thumping the water...
They all say they have enormous insulation, use the latest techniques, have the most therapeutic nozzles, blah blah.
And I have never heard of any of them.
the one that fits the best at the end of my back porch has 225 gallons, a 7hp single pump, 26 outlets in six varieties, and a three year everything warranty.
It has a 4kw heater and is only 60 inches wide so it fits just perfectly, albeit with a house jack and a brace underneath. No way am I putting a ton of weight on one spot on that deck. It's only a three foot drop but...
what should I look for, ask for?
I asked about heating with propane and was told the conversion was not inexpensive and to try the electric first. It was so well insulated the energy cost is low, blah blah. Yeah, maybe for the Sultan of Brunei... So lastly, what does it cost to run one of these things on some kind of set back basis so it isn't kept all the way hot all day? I would use it every day, likely morning and night.
Thanks very much for feedback. Drew
/ Hot Tub Experiences? #2
I have a 6 person softub. 115 V and heats with scavenged heat from its 1 hp circulating pump. I too have it for chronic arthritis and it is a life changer. Cost to operate is approx $25 a month for electricity. Maybe $4 a month for chemicals. Holds 300 gal. Always on and very well insulated and is in an unheated porch. I believe today's canadian cost is around $3500. I have no regrets or complaints.
/ Hot Tub Experiences? #3
Insulation is the key to low cost. In my research (dont have a tub yet) operating costs can vary greatly depending on brand.
For me Beachcomber is leading the way. They are very well insulated and well made. All the stuff Ive read on the web (and looking at the tub in person) leads me to believe that. The one Im looking at from Beachcomber is a model 500 Hybrid (I think).. Its supposed to add about $30/month to the power bill on average for the year (this is from the government Energy sticker on it) . As a comparison, a close friend has one and its almost bankrupted him from the high power bills. He's said its added $300 to his bill in winter.
I dont want a "party tub" either. Just high quality powerful pumps and low operating costs.
Be well aware and do a TON of research. There are lots of fly by night and ever some established brands out there with a lot of problems and high operating costs.
/ Hot Tub Experiences? #4
Drew you know this will limit you to 2 ladies at a time in the tub?? :D Just sayin...........
/ Hot Tub Experiences? #5
We have had a three-person tub for several years. Small is good. Fairly painless to maintain. We change the water a couple of times per year - but it's really my wife and me in the tub. I don't think that we spend more than $20/month with electricity and chemicals. Funny thing is that we'll use it in the snow, but not in the rain. Good luck.
/ Hot Tub Experiences? #6
Boy that's sounds pretty good right about now. Been on the backhoe most of the day, except for an hour or so tight in loose joy sticks.
/ Hot Tub Experiences? #7
I have several friends with tubs. Can't really add much insight to brand new tubs.
I have been involved in fixing broken ones. Pumps, control boards and heaters seem to be unique and expensive.
God forbid there is a leak in the tubing and fittings. Took the sides off and it looked like two drunk hillbillies had sprayed the tubing and tub with foam. Not a professional looking build. Had to cut / scrape the "insulation" off until we found the leak in the flexible tubes.
Hot tubs kind of remind me of campers and rvs. Look pretty good on the outside. Take the skin off and it's pretty much hacked together.
/ Hot Tub Experiences? #8
I have several friends Can't really add much insight
God forbid looked like two drunk hillbillies we found the leak in the flexible tubes. Look pretty good on the outside. Take the skin off and it's pretty much hacked together.
Hmmm.
/ Hot Tub Experiences? #10
After 25 years of hot tubs, 5 of them but larger than you are considering, I've found that you get what you pay for. Buy the most expensive one you can find that still rates well.
Research the Internet. It would be nice if Consumer Reports or a similar service did a review on them. They don't so you have to rely on posts on forums.
My most recent one is a Hot Springs brand. It has held up for 7 years with a couple of electronic problems. Still operating like new. Now just wait until tomorrow!
one of the things I'm looking at is the total amp consumption rating. The one proposed to me shows a 50amp requirement. Others require higher amperage, 64 I think I saw on one of them. That's a hefty draw for sure and what if the hvac systems are on at the same time.
I have a 400 amp service so I'm not concerned over the ability to feed a hot tub but it seems this appliance would be the highest draw device on the panel.
Although I'm not sure what a four burner stove would draw with all four burners on plus the oven. Let's turn all that on at the same time too...say for Thanksgiving.
I believe the 4kw heater is the highest consumer, followed by the 7hp pump followed by the circulation pump; the latter using less than one amp.
That's a lot of juice...really surprises me the monthly cost figures quoted are so low.
/ Hot Tub Experiences? #12
We are on our second hot tub- the first one was a Sun tub,
5 person round with a 1 1/2 hp dual speed motor, 240 vac .
It had numerous problems including being mis-plumbed from the factory.
The worst thing was the solid insulation... the tub developed some leaks in its later years and the insulation made it near impossible to find and fix problems.
Never again...
Our replacement tub is a square one also 5 person with a reclined bench (spa Warehouse) with removable sides and replaceable insulation, 4 hp jet pump and a separate 1/16 hp circulation pump which we run 24 / 7 it also has knife valves which can be closed to work on any of the pumps or heater Without draining the tub ... I much prefer a serviceable tub to the other one.
If I was looking at a new one , would give a Thermo-Spa a good look
/ Hot Tub Experiences? #13
I bought a $4000.00 4 person Vita Spa on craigslist for $500.00 that was 10 years old. I have had to replace the heater, $39.00.
I keep the temp set at 98* and I can stay in it as long as I want to. You can feel the heat soaking into your bones!
Buy the best brand that you can afford and skip the FOO FOO accessories.
The bigger the heater the faster it can warm up from being turned off.
I am also using some kind of copper additive to sanitize the water and it works great and doesn't stink.
/ Hot Tub Experiences? #14
I got a small one for free about twenty years ago. The upside was free and the equipment was quality. We liked it so much that when I had a chance to get a much nicer one just for the taking I jumped on it. We haven't used it in years and have a standing offer of free for the taking.
The upside is they are very relaxing in the evenings, especially when it's downright cold outside. The combination of snow on bare skin in hot water is a true treat. And when the grandkids were small letting them play in it was a ton of fun.
The downsides are cost of heating, ours has an electric heater, and keeping the water safe. One of my clients explained to me the importance of having the water just right chemically. You slip into the tub and your body oils mess it up and it needs to be balanced back out. Now two of you slip in and it's even worse. Keeping the water safe is a full time job if you want it to be right. With a swimming pool the amount of water lessens the impact of your presence. Hot tub? whole different game.
/ Hot Tub Experiences? #15
have ya looked at a DIY setup? epdm style liner, with tile work over the liner?
diy hot tub as far as the tub itself, is not much different than a diy above ground pond or pool. same basic liners used, add some tile over the liner. and away ya go.
the main difference as far as tub itself is the drains, and air/water returns on a hot tub. they can get rather fancy.
air pump, water pump, heater, switches, thermostat, control board.
some hard board insulation, along with some spray foam, to insulate it all up well.
heck you could turn a cheap swimming pool into a hot tub.
/ Hot Tub Experiences? #16
I can't remember (off hand) the brand I have. It has a circuit board and auto cycles from time to time. Has 2 Motors. I believe 1 is a 5 hp and the other is a 4 hp. I've only had to replace the heater so far. Had it about 5 yrs
/ Hot Tub Experiences? #17
- Wire it for full power. We had to use ours temporarily on 115 while our deck was rebuilt. It works MUCH better on 220. For the the multi voltage/current models, unless you wire fore max power, it will not heat while jets are on, heats slow etc.
- Someone mentioned earlier, you get what you pay for. Our last spa was expensive, but lated14 years of heavy use. We could have went cheaper, but it was worth the extra for better build, better insulation etc. Had friends with cheaper ones, last half as long, and they did not use them near as much as we do(my wife uses twice a day for aqua therapy, every day)
- They need the water changed. Ours is smaller round 4-person. 4-6 months on water between changes
- We live in N. Calif, with mild temps in winter. Not sure what you folks go thru in the colder climates. Can you use year round, no freeze issues?
/ Hot Tub Experiences? #18
Speaking of DIY hot tubs and small ones...several year ago a guy I know was telling us (quite proudly too) about what he scrounged to make his own small hot tub. The City of Saskatoon used to use large garbage containers in the back alleys that were supposed to be sized for four households. When they became damaged for whatever reason, they were switched out and the old ones were stored in one particular City Yard. You could buy these if you wanted (a friend has half a dozen that we cut the top off to make planters, works great for that) so this guy bought one of the least damaged ones to make his hot tub! GACK! I don't care how much cleaning and bleaching you do, all I can think of is all the various different liquids that soaked into that thing over the years...and picturing sitting in a soup of that stuff.
/ Hot Tub Experiences? #19
Don't get one with molded-in "bucket seats." Get one with "bench seats."
Much easier to relax when you can change position.
And you don't need 800 jets. :)
Bruce
/ Hot Tub Experiences? #20
Hot Tub Experiences
Wow! the topic of this thread is a little disappointing to say the least.
Charlie
