Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,219
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
I bought an MS201T in 2013 and have NOT been happy with it. Took awhile but I figured out how to fix it reading posts on Arborist forum. I followed the posts and it's a little hotrod now. Basically did 4 things.
1) Bent a little lever up (like a float valve lever but it's on a diaphragm).
2) drilled a hole in the muffler
3) filed the flywheel key a little to advance the timing. Site recommended 6-8degrees but I did about 4*.
4) defeated the limiters on the "mixture adjust" screws
Anyway it's a LOT snappier now and pulls HARD with the bar buried. I am impressed. It kinda has some 'run-on' when I let the throttle off. I can't get this to go away, it's like a mid-range leanness, not affected by the high or low screws.
Any tips on tuning the H/L screws? I got the initial settings from the Arborist site, but don't know where I'm at right now. Will put them back and start over. Apparently this saw is difficult to tune the "H" because it's electronically rev-limited. I've been choosing a setting based on how hard I can push on it with the bar buried, then open it 1/8 turn further, and it still has that lean 'run-on' when I close the throttle. And it sorta 'runs dry' after ilding a little while.
