hot hydrostatic in a Cub 5252
   / hot hydrostatic in a Cub 5252 #1
Cub5k
Maryland
Cub 5252
I have a Cub 5252. The transaxle seems to get excessively hot after using the pto (mmm) for 30 minutes or so. The 3pt lift arms which attach to the trans get hot to the touch. The dealer tells me its normal but I'm not so sure. Hydro oil is full and fan is ok with no air blockage.
   / hot hydrostatic in a Cub 5252 #2
Most Hydraulic systems on tractors run about 100 degree over ambient temperature.
When I checked my Hydraulics on a 80 degree day the temperature was 185 degrees.
It will not burn on contact, but you will not touch it for long. /forums/images/graemlins/blush.gif
thanks, I ordered a cheapo surface thermometer so I can check it next time.
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2020 JOHN DEERE 332G (A50854)
2020 JOHN DEERE...
Caterpillar Front Glass (A50854)
Caterpillar Front...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A50854)
2014 FORREST RIVER...
