Hot Dog
/ Hot Dog #1
rdsaustintx
Texas Hill Country
Kubota BX-23
Took an IR photo of my tractor after digging about 30' of trench. By "digging" I mean wedging your BH under rocks and roots, listening to your relief valve sing and flopping the FEL against the ground. I was flailing.
It was a little over 90 here and the cylinders are about 160 deg. No telling how hot the innards of the HST get. The rule of thumb that the hydraulic fluid runs about 100 above ambient looks pretty valid at this point.
/ Hot Dog #2
Very interesting photos...Thanks for sharing!
Don
/ Hot Dog #3
Thats cool, what kind of camera are you using? Something like that would be excellent for electrical panels.
/ Hot Dog
ICI toughcam. Yeah, if you dial it in close enough (minimum span), ALL electrical panels look scary. :)
/ Hot Dog #5
Cool photos :cool: , thanks.
I use an infrared no-contact thermometer, fairly cheap these days, <$40. Every so often I check out various components on my equipment and its a great troubleshooting tool. Radiator, thermostat, intake/exhaust manifolds, engine block at each cylinder, crankcase, alternator, hydraulic pump/cylinders/hoses, wheel bearings, you name it. Very interesting stuff to compare the various operating temperatures.
Also works good in the house for checking hot/cold spots, eg measure an inside wall then various components on the exterior walls: walls, window frames, doors, brick wall behind the wood stove, water heater enclosure, etc.
/ Hot Dog #7
Dr. Bob said:
Yes, very interesting. Where do you get one of these "no contact thermometers" for less than $40? I'd really like to use it for the tractor AND the house when considering insulation.
I bought mine from Kragen when I was trying to diagnose an overheating problem on my Toyota. I think I paid $56. I was half way through a 5 hour trip and didn't have time to shop around. Since then I've seen them for around $40 or less at Harbor Freight and sometimes the local Kragen and Auto Zone stores has them on sale for around this amount.
I use it in the shop too to check operating temperatures of motors I've put under heavy load for long periods like planing a unit of lumber. I've also checked the temperature of my welders to make sure I was not overheating them.
/ Hot Dog #8
Sears has one for $49.99. Page 103 of their new 2008-2009 tool catalog.
"Craftsman Laser-Directed Non-Contact Infrared Thermometer. Measures surface temp from -58 to 518 degrees with 2.5% accuracy. Accurate to 6 feet"
Their top-of-the-line model measures -58 to 1832 degrees but it's $179.99
/ Hot Dog #9
Bx2230Dude,
Got to be an interesting story behind your avatar. Do you know and want to share?
/ Hot Dog #10
That kind of stuff happens around here when people from out of state park on the wonderful beach, go for a hike and the tide comes in. Although I must admit they don't tend to travel in commercial TLB's.
/ Hot Dog #11
Nothing like a TLB for building one heck of a sand castle..:)
I had to change avatars recently. This is not my TLB (I have a Kubota L39). This TLB was stolen and driven into the water by some miscreant. The picture shows how it was found by the police. I got a chuckle out of the picture and figured it would make an amusing avatar. So far two people have asked "what happened to your TLB". If 20 more people ask and I reply to each one I'll become a Silver member. Only 9900 posts to go before I reach Superstar status. :)
In the future I'll probably explain it by saying "Don't try to finish your 2nd beer before operating your backhoe".
Club Car Carryall 2 Electric Utility Cart (A64553)
Club Car Carryall...
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2015 FREIGHTLINER...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
2018 Infiniti QX60 SUV (A64557)
2018 Infiniti QX60...
2007 FREIGHTLINER COLUMBIA TANDEM AXLE 6 X 4 TRUCK TRACTOR (A67147)
2007 FREIGHTLINER...
2007 Ford F-150 Pickup Truck (A64194)
2007 Ford F-150...
