Hose size?
   / Hose size? #1
galaxie428
Rushville, IN
Bobcat CT230
I am in the process of buying a Woods BH80X backhoe for my CT230 that I will run off my rear remotes and I am not sure what size (dia) of hose I need. I was looking on Agrisupply and they have 1/2" and 3/8" hose. Here is a link to an example of both. Which one do I need or will neither one work? I am not sure what it means by 2 wire hydraulic hose.
60 LONG X 1/2 HYDRAULIC HOSE W/ONE SWI - Agri Supply
42 LONG X 3/8 HYDRAULIC HOSE W/ONE SWI - Agri Supply
Any help or advice would be appreciated.
   / Hose size? #2
I dout either will work to small i would say 5/8 or 3/4 but i may be wrong. the 2 wire is just the strenght of the hose which a 2 wire brade would be a strong hyd hose. Hope that helps.
   / Hose size? #3
Hose size is determined by the GPM rating, His machine is rated for 7.9 GPM so 5/8 or 3/4 is WAY overkill! Add to that he is running it from the rear remotes.
You will only need 3/8" hose, but 1/2" would be just a little better. 2 wire 4000 PSI rated hose is what you want.
   / Hose size? #4
The hoses on my Kioti CK30hst going to a Kioti KB2375, 7.5 foot bh, and similar to a CT230, are 1/2 inch.
   / Hose size? #5
We use 1/2
If you are going to have hoses made you will need a male 3/8 NPT on one side and a male #8 o-ring boss on the other side.
4-5' of hose is sufficiant.
If you would like you can pm me your address and I can give you a to your door price. I can even include the male end to plug into your tractor if need be.
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
DOOSAN G70 PORTABLE GENERATOR (A52472)
DOOSAN G70...
2024 KMC 7406 (A53084)
2016 Dodge Caravan Van (A50324)
2016 Dodge Caravan...
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52748)
2017 Rogator...
