Hose size for toplink cylinder?
   / Hose size for toplink cylinder? #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
Make any difference what size hose I use?
Cat II 3pt. 3" cylinder. As short as these hoses will be cost is not the deciding factor.
So 1/4", 3'8" or 1/2" ?
   / Hose size for toplink cylinder? #2
I have 3/8 and it is plenty.
   / Hose size for toplink cylinder? #3
I would use the 1/4 inch hose in a effort to slow down the flow of oil so the cylinder wont move too fast. I would also install flow restrictors in the lines if I could find some. I had no luck finding any locally the last time I wanted some.
   / Hose size for toplink cylinder? #4
1/4 in hose and a needle valve.
My rear SCVs, JD deluxe 301 series made by Husco, have built in flow control. Will that be enough with 1/4" hoses?
   / Hose size for toplink cylinder? #6
Probably. Connect up the 1/4 in hose and try it.
   / Hose size for toplink cylinder? #7
My JD 3rd SCV kit has the huge back hoe quick couplers, not sure on the hose but is definitely bigger than 1/4". There must be some type flow restriction in the system somewhere cause it doesn't move to quickly, very much in control. Could just be the cylinder.
When I hooked up a truck's snow plow to the rear remotes, even though they have 1/4" fittings the plow moved so fast I could do an NHL slap shot!
JB
   / Hose size for toplink cylinder? #8
   / Hose size for toplink cylinder? #9
Mine are 3/8" and I should of used 1/4". I'm putting a needle valve on it to slow it down.
   / Hose size for toplink cylinder? #10
I have flow restrictors, $10 ea + shipping. Install right behind your male quick connect end. 1/2" pipe thread.
2014 UTILITY DRY VAN TRAILER (A51222)
2014 UTILITY DRY...
2010 CATERPILLAR MINI EXCAVATOR 303C (A50854)
2010 CATERPILLAR...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
TOOLBOX (A50854)
TOOLBOX (A50854)
