Grapple Hose Size For Piranha Root grapple
   / Hose Size For Piranha Root grapple #1
ksmmoto
Central Lower Michigan
Kubota L3430
I just bought a Piranha 66" Root Grapple for my Kubota L3430. It has 1/4" hoses with flat face skid steer connectors. I am going to change the connectors and run hoses from the loader valve. Checking on the V & M Hydraulic Multiplier Valve.
Is 1/4" hoses big enough? The LA513 Loader I have has 3/8". I will post more on installing and using this bucket and some of my other projects soon. Getting the yard caught up and I need to take photos.
ksmmoto
   / Hose Size For Piranha Root grapple #2
The 1/4" hose will be fine for the grapple, because the grapple cylinder is not being cycled that often and does not require alot of flow to operate. It may even help slow the cylinder down for better control without using inline restrictors.
If you were operating a hydraulic motor, you would need bigger lines.
   / Hose Size For Piranha Root grapple #3
I'm with Kenny most grapples cycle way too fast anyway for good control. Use the 1/4 inch hoses that you have and have fun with your new grapple.
Don't forget to post a few pictures of your new grapple in action after you go out to play.
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
2010 Kaufman Gooseneck Trailer (A59814)
2010 Kaufman...
2022 Dodge Ram 4500 Miller 8,000lbs Wrecker Tow Truck (A59230)
2022 Dodge Ram...
2022 CATERPILLAR 299D3 XE SKID STEER (A60429)
2022 CATERPILLAR...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
