Loader Hose leaking in channel
   / Hose leaking in channel #1
mx5guy
Carp, Ontario
Kioti CK27 HST
Hi everyone, not sure if this has happened to others, and I have read about it happening to BH but not to FEL. One of the cables from the 4 QC's that pass through FEL arm to the T's where they match with corresponding colour coded QC off to different cylinders. Where the first go in to the oval hole in the arm, snug fit, and one of the cables must of rub its way through against the edge of the hole as it was leaking a lot, I would guess I will need to use some rad hose or heater hose to better protect the cables. My Kioti has less than 100 hours so anyone else out there should check for ware in the protective gauze type material over the hoses for wear and protect your hoses, before it happens to you, mine is a CK27 HST.
Kioti replaced two hose sight un seen. Great warranty service.:thumbsup:
This must not be a isolated case, so might be a good thing to check your hoses.:) Just in case, as new FEL's only have a one year warranty.
2020 DRAGON ESP...
2018 Ariens Ikon 52in Zero Turn Commercial Mower (A56857)
2018 Ariens Ikon...
2013 International Derrick Digger Truck (A55973)
2013 International...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
Mini Margaritaville Truck (A55853)
Mini...
