Loader Hose leaking in channel
   / Hose leaking in channel #1
mx5guy
Carp, Ontario
Kioti CK27 HST
Hi everyone, not sure if this has happened to others, and I have read about it happening to BH but not to FEL. One of the cables from the 4 QC's that pass through FEL arm to the T's where they match with corresponding colour coded QC off to different cylinders. Where the first go in to the oval hole in the arm, snug fit, and one of the cables must of rub its way through against the edge of the hole as it was leaking a lot, I would guess I will need to use some rad hose or heater hose to better protect the cables. My Kioti has less than 100 hours so anyone else out there should check for ware in the protective gauze type material over the hoses for wear and protect your hoses, before it happens to you, mine is a CK27 HST.
Kioti replaced two hose sight un seen. Great warranty service.:thumbsup:
This must not be a isolated case, so might be a good thing to check your hoses.:) Just in case, as new FEL's only have a one year warranty.
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Kubota RTV500 (A47384)
ITEM LOCATION (A53084)
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2014 Ag Spray Schaben Sidedresser (A52748)
2014 Ag Spray...
