Horsepower? Gas vs. Electric Motors
   / Horsepower? Gas vs. Electric Motors #1
Spencer
Western Michigan
NH TC33D w/R4 Tires, Rear Remote, Hydraulic Toplink, 2 Auxiliary Work Lights, 7308 Loader w/Kasco Uni-Hitch (Quick Tach)
I have a new cement mixer on the way. The unit I bought came in both a gasoline and electric versions (see attachment). I chose the Honda gas engine model for freedom of use. My question is how come the electric motor (110 volt, 6 amp) is rated at 1/2 horsepower and the gas engine is rated at 2.5 horsepower? Both motors will have the same load on them and perform the same task so what gives with these horsepower ratings? Just wondering, and hoping to learn something new.
   / Horsepower? Gas vs. Electric Motors #2
I think you would have to look at the torque ratings and/or the gearing of the electric vs the gas engine models. Generally speaking, the electric motor is probably going to run at a much higher rpm than the gas engine and would be geared differently. You know the old saying, you can run a locomotive with a pocket watch if it is geared correctly (albeit not very fast /forums/images/graemlins/smirk.gif).
   / Horsepower? Gas vs. Electric Motors #3
A gasoline engine produces a finite amount of horsepower and is rated at the maximum it will produce under ideal conditions. An electric motor will produce many times its rated horsepower when the load demands, but at the expense of temperature rise. The rating given is usually conservative and is intended for continous duty.
The normal replacement for a 1 HP electric is a 3 HP gas. 1/2 to 2.5 HP seems a bit excessive; maybe 2.5 was the smallest engine they could find.
   / Horsepower? Gas vs. Electric Motors #4
Well, one thing that was not pointed out in the ad, is the SAME gearbox being utilized for either the electric version & the gas engine version? There may be two different gearboxes used depending on what's driving it, the gear ratios may be different and allow the smaller horsepower to perform the same job, may not rotate the drum at the same RPM as the gas version does.
J.W.
   / Horsepower? Gas vs. Electric Motors #5
The electric motor will produce maximum torque at zero RPM while the gas engine has it's peak torque at some higher RPM.
Starting the mixer turning will require the most torque.
Egon
   / Horsepower? Gas vs. Electric Motors #8
I have never used a gas engine mixer, but I guess I was assuming it had some kind of clutch mechanism so that the engine was already running at rated rpm when the drum was engaged. /forums/images/graemlins/confused.gif Help educate me here.
   / Horsepower? Gas vs. Electric Motors #9
Mine uses a gear reduction via a belt drive and then a gear from that. It will easily run the mixer at idle though. When you pull the rope, the drum turns. No clutch is really needed in this case although there are times when turning the rotating drum off without killing the engine would be handy, you know like when you get the shovel stuck in there and the handle is rotating wildly out of control taking out everything in its path. Rat
   / Horsepower? Gas vs. Electric Motors #10
RaT
That one made me laugh! /forums/images/graemlins/laugh.gif Been there done that! /forums/images/graemlins/shocked.gif
200992 (A54756)
200992 (A54756)
HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
HarbinGer V3 Plus...
377811 (A48836)
377811 (A48836)
2005 JLG 660SJ TELESCOPIC MANLIFT (A52705)
2005 JLG 660SJ...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
