Volfandt
Veteran Member
Most all small diesels are indirect injection. I don't know of a direct injected small diesel but that doesn't mean there isn't one out there.
The way it was explained to me was that indirect injection allowed for a better mixing of the fuel/air which allowed for a more complete combustion in the smaller diesels.
The size of the combustion chamber area above the the piston has a direct influence on whether a diesel uses direct or indirect injection.
The smaller diesels having a much smaller combustion chamber area above the piston doesn't allow for an optimum mixing of the fuel/air mixture as well as not maintaining the cylinder temperature at the desired rate. The premixing in an indirect injection engine offsets these shortcomings.
Larger diesels with their larger volumetric capacities have no problem mixing the direct injected fuel with the compressing air and they maintain their combustion temps better to where indirect injection isn't requred.
It all has to do with the size (bore & stroke) of the engine than anything else.
What the happy median is that determines which method is best, is, well beyond me
Volfandt
Volfandt
