horsepower and fel capacity boost 2810hst
   / horsepower and fel capacity boost 2810hst #1
gav64
Eastern Connecticut
Mahindra 2810hst - Gehl 4625 skidsteer
good morning, now that the warranty has expired is there any way to boost the horsepower and front end loader capacity on a 2810hst. the engine bogs down going up hills even in low and the lift capacity on the loader seems very low for the size and weight of this tractor. thanks glenn
   / horsepower and fel capacity boost 2810hst #2
I'm suprised the engine bogs. Mine has good power. Does it only do it when using a pto attachment, like a brush hog, or at all times?
For FEL lift capacity, you can upsize the lift cylinders, I did and am happy with it. I bought them from Wallace Tractor.
   / horsepower and fel capacity boost 2810hst #3
Fel, larger cylinders, but will slow the motion a bit by volume pumped as long as the rest of the materials will take the strain. What altitude are you at? How old or many hours is the machine? What RPM are you running?
   / horsepower and fel capacity boost 2810hst #4
That's a good point to bring up. Using cylinders that are much larger could cause issues down the road from overloading the design.
I know Rick Wallace consulted with the loader manufacturer (KMW), so we stayed safe. I haven't really noticed any slow down of FEL operation. I did notice better lift capacity, mostly breakout force. It's a good mod to make if you don't mind spending the $.
JOHN DEERE LOT NUMBER 72 (A53084)
JOHN DEERE LOT...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
JOHN DEERE 520 SHREDDER LOT NUMBER 253 (A53084)
JOHN DEERE 520...
2015 Caterpillar 410L 4x4 Extendahoe Backhoe Loader (A51691)
2015 Caterpillar...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
