Horse power vs tiller width
   / Horse power vs tiller width #31
I run a 4' tiller with my new holland s14 in hard clay. Sometimes I have to make multiple passes to get to the max depth, but it does the job.
I like the looks of your garden tractor. I have never seen one of those. I looked it up on tractor data. Looks like they made them from 1970-73. They also made an S12 and S16. Looks like you are keeping it busy.
   / Horse power vs tiller width #32
I run a 5' tiller on a 28hp tractor. Tills CT rocky soil no problem. Can you rent a tiller and try it out on your tractor on your soil? That is the best way to answer your question. Anyone near you have a tiller you can borrow?
   / Horse power vs tiller width #34
2320 deer compact @19 PTO hp works just fine.
I'd like to find an 8' tiller for my 40 PTO hp MX. And only reason I'm not looking for a 10' is cause I don't want to have to get an oversized permit to trailer it
   / Horse power vs tiller width #35
Tiller width is one thing, rotor diameter is another. A large rotor type in 10 feet width may require 150 hp to run it. that is 15 hp per foot.
But for your 6800 I agree that a 72" wide tiller with 7 to 8 inch working depth would be about perfect size. That would have about an 18" -to-20" rotor diameter. Six cutters per rotor for about 54 cutters total.
Thank you for the reply. Most of the 6’ tillers I’ve seen are rated for 40 to 50HP at the PTO. Any concern with the higher HP on my PTO?
   / Horse power vs tiller width #36
Where’s the weakest link? And how expensive is it?
The weakest link should be a PTO slip clutch or a shear bolt that will snap instead of more expensive parts snapping. However, there is difference in the horsepower a shear bolt or slip clutch will let through in a normal “steady state” condition, working as it should, versus the dynamic horsepower spike of a rock jamming the tiller to the point it snaps the shear bolt or slips the clutch.
IMHO, having a 100 hp tractor on a 40-50 hp isn’t a problem as the shear bolt and clutch will protect the tiller if something jams it.
….but it probably will let you work the tiller harder at (say) 60 Hp. Could you continuously apply excessive horsepower for hours and overheat the gearbox? Maybe. But if the gearbox stays cool, it’s probably ok. Heat and impacts are when stuff fails. Those rating numbers are fuzzy.
Conversely, IMHO, a small hp tractor running equipment rated for larger horsepower should have a shear bolt or slip clutch at a setting that protects the tractor’s PTO from sudden impacts.
   / Horse power vs tiller width #37
the S14 is a great tractor, i have 2 of them. One with a cab and snowblower, the other with the tiller and plow. The tiller one my father bought in the 70's. Great machines, very reliable, and easy to work on. I see them pop up for sale between 300-1000 on occasion with various accessories.
   / Horse power vs tiller width #38
62hp tractor will "properly" run a HD 6' tiller pretty much anyplace, continuous duty.
In gardens or lighter soils, even a 7 footer...
SR
This is about it. Max. Trying to use a 12 foot tiller on something this small is just playing with it.
We’ve always worked on an inch per hp minimum when you’re working heavy ground.
Some of the bigger hoes and tillers use a 250hp tractor to run a 160 inch hoe. At 2 miles an hour.
At the end of the day if you have plenty of hp you’re going to do the job properly on the first pass and probably save yourself heaps in the long run.
   / Horse power vs tiller width #39
You will likely run out of traction before you run out of PTO horse power, depending on tractor speed, soil type and depth of tillage. Weight is your friend with tilling. :)
   / Horse power vs tiller width #40
I have a JD3025D and I want to get a tiller. Does anyone run a 5ft tiller with a 25 hp tractor? I would like your input if you do. I have sandy soil so I think it will be fine, but I would sure hate to spend that much money and be disappointed with the results. Thank you in advance for your help.
Back to the OP, and think the JD3025D will do just fine running a 5' tiller, especially if it is HST where infinite forward speed is available.
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2006 International 9400i (A55302)
2006 International...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A52709)
2016 CATERPILLAR...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
